> Flying through a Valve adjustment, and discovered why car was running BAD!!!!
Noodles
post Sep 1 2012, 07:15 PM
OK first off I'm a complete noobie. Have had my teener for about 2 months now so I'm learning everything as I go.
Today I tore off my valve covers because car started running very badly. Had a big miss and lost almost all power. Was adjusting valves starting at 1 and working my way around, had a few that were in need of adjusting then I got to number 4 and found this.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1028.photobucket.com-14688-1346548525.2.jpg)
The nut was sitting in the bottom and the washer is just missing. Ran a magnet around and just no luck finding it. Dont know if its in the bottom end or what.
I got some new washers and tightened it down but now it pushes the rocker down to far once its good and tight, (I think thats what its called, like I said I'm very very new) and I cant get a feeler gauge in to adjust the valves, Its pushed way down below the spring and very tight. I can move the far right one but the one on the left wont budge whatsoever.
Any help and advice would be much appreciated. Am I going to have to tear this all apart and redo it or am I just missing something easy?
cgnj
post Sep 2 2012, 11:56 AM
I would check all of of the push rod tubes.I find it had to believe it could have walked into into the sump past the lifter. Are those swivel feet? I see rocker spacers.
I don't worry about the the flywheel mark except for #1. I just turn till the exhaust moves then back up.
Carlos
aircooledtechguy
post Sep 2 2012, 09:13 PM
The Aircooledtech Guy
QUOTE(cgnj @ Sep 2 2012, 10:56 AM) *
This was the whole point of my post above. A washer won't even get to a lifter due to gravity. IT WILL FALL INTO THE SUMP PRIOR TO THE LIFTER. Have you ever seen the inside of a case lately?? There are HUGE oil drains that are outboard of every lifter and just inboard of every push rod. If there were no drains, all the oil would stay in the heads and eventually you would have none in the sump.
Noodles   Flying through a Valve adjustment   Sep 1 2012, 07:15 PM
bandjoey   http://www.914world.com/bbs2/index.php?showtopic=2...   Sep 1 2012, 07:20 PM
Noodles   http://www.914world.com/bbs2/index.php?showtopic=...   Sep 1 2012, 07:58 PM
Bob L.   I'll bet it went down the oil return tube. If ...   Sep 1 2012, 07:48 PM
rhcb914   I would take that assembly out and see why you los...   Sep 1 2012, 08:27 PM
Dave_Darling   If that cylinder is at TDC, there should be some s...   Sep 1 2012, 08:29 PM
rick 918-S   If that cylinder is at TDC, there should be some ...   Sep 2 2012, 07:19 AM
dirk9141973   I had this problem or about the same 1. Check th...   Sep 1 2012, 08:46 PM
dirk9141973   I had this problem or about the same 1. Check t...   Sep 1 2012, 09:03 PM
brant   also when those shafts get loose, the pushrod fall...   Sep 2 2012, 12:34 AM
etcmss   so where is the washer? can it be affecting prope...   Sep 2 2012, 04:39 AM
The Cabinetmaker   I don't see how the washer could have made its...   Sep 2 2012, 06:55 AM
The Cabinetmaker   I don't see how a washer could get past the li...   Sep 2 2012, 09:34 AM
euro911   I don't see how a washer could get past the li...   Sep 2 2012, 11:31 AM
aircooledtechguy   I don't see how a washer could get past the l...   Sep 2 2012, 11:45 AM
Noodles   Thanks so much for all the replies, I'll be te...   Sep 2 2012, 09:45 AM
cgnj   I would check all of of the push rod tubes.I find ...   Sep 2 2012, 11:56 AM
aircooledtechguy   I would check all of of the push rod tubes.I find...   Sep 2 2012, 09:13 PM
- Lo-Fi Version Time is now: 18th April 2026 - 07:03 AM
