| kbrunk1 |
Sep 3 2012, 09:50 AM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Haynes and Climer books say you clamp one side (one piston) then use air to push out the other side.
I have a small compressor. I am assuming you closed both bleed valves and then apply air to where the hydrolic line comes in. When I do this I can not get the piston to come out. Do you have to get a threaded fitting and then apply air pressure? I was just pressing a "riggged tape tip nozzle" and most likely am not getting sufficient air pressure. Right side caplider brakes seems to be fine (move in and out easily when clamped) and I was just going to put a kit in because it is so old. The Haynes book says to not split the caliper unless you have to. The other front caliper seems to have a stuck piston because when clamping it it will not move. I am soaking in brake fluid and will see..... Any help here? |
| Brian_Boss |
Sep 3 2012, 10:26 AM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
If you use the search feature, Eric Shea has posted a lot of good info on this.
The threads on the caliper fluid inlet are close enough to 1/8NPT and that is what most air blow guns have on the tip. Remove the tip, insert pipe nipple, thread into caliper for air tight connection. |
| Bartlett 914 |
Sep 3 2012, 10:44 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
If you use the search feature, Eric Shea has posted a lot of good info on this. The threads on the caliper fluid inlet are close enough to 1/8NPT and that is what most air blow guns have on the tip. Remove the tip, insert pipe nipple, thread into caliper for air tight connection. Worse comes to worse, use a grease gun. Fill the caliper with oil. any oil will do. Install a grease fitting and use some old cheap grease in a grease gun. Pump this and it will come out. I did not use a grease fitting. I screwed directly the grease gun in the caliper so if the fitting doesn't work, try that. |
| kbrunk1 |
Sep 3 2012, 11:46 AM
If you use the search feature, Eric Shea has posted a lot of good info on this. The threads on the caliper fluid inlet are close enough to 1/8NPT and that is what most air blow guns have on the tip. Remove the tip, insert pipe nipple, thread into caliper for air tight connection. Worse comes to worse, use a grease gun. Fill the caliper with oil. any oil will do. Install a grease fitting and use some old cheap grease in a grease gun. Pump this and it will come out. I did not use a grease fitting. I screwed directly the grease gun in the caliper so if the fitting doesn't work, try that. If it turns out to be corroded then do you have to split the capliper and then use a small drill honing device? I am curious how the fluid gets to the other side when you split a caliper? When the caliper is put back together is simply a compression fitting or is there a seal of sorts? |
| jcb29 |
Sep 3 2012, 12:46 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 29-August 04 From: Clovis, CA Member No.: 2,646 Region Association: Central California |
QUOTE I am curious how the fluid gets to the other side when you split a caliper? When the caliper is put back together is simply a compression fitting or is there a seal of sorts? There is a small hole drilled thru the spacer block with small rubber washers on either side. |
kbrunk1 How do you get Pistons Out for Front Brake Calipers Sep 3 2012, 09:50 AM
9146986 That is the correct procedure. If you have some e... Sep 3 2012, 10:04 AM
Brian_Boss Here is a thread with a lot of good info:
brake th... Sep 3 2012, 12:59 PM
wingnut86 Grease gun works every time on stuck ones. Make s... Sep 3 2012, 03:40 PM
Elliot Cannon The best advice you can get is from Eric Shea. (N... Sep 3 2012, 04:05 PM
Eric_Shea For what you're up against, fluid will probabl... Sep 3 2012, 04:20 PM
kbrunk1
For what you're up against, fluid will probab... Sep 3 2012, 08:26 PM
kbrunk1
[quote name='Eric_Shea' post='1733492' date='Sep ... Sep 3 2012, 08:52 PM
euro911 Nice clip :thumbsup:
You make it all look fast a... Sep 3 2012, 08:17 PM
wingnut86 Elliot is just jealous because the word Skeet was ... Sep 3 2012, 08:31 PM
Elliot Cannon
Elliot is just jealous because the word Skeet was... Sep 3 2012, 10:11 PM
wingnut86 You send him complete ugly ones, or those with mis... Sep 3 2012, 09:35 PM
Eric_Shea We use a vibratory polisher on the pistons. Then w... Sep 3 2012, 10:52 PM
get off my lawn Using air pressure can be dangerous, a small canno... Sep 4 2012, 03:45 PM
pilothyer Grease gun and water........no muss no fuss :D Sep 5 2012, 03:36 AM
stugray I had a flat piece of 1" teflon laying around... Sep 5 2012, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 02:54 AM |
