| kbrunk1 |
Sep 3 2012, 09:50 AM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Haynes and Climer books say you clamp one side (one piston) then use air to push out the other side.
I have a small compressor. I am assuming you closed both bleed valves and then apply air to where the hydrolic line comes in. When I do this I can not get the piston to come out. Do you have to get a threaded fitting and then apply air pressure? I was just pressing a "riggged tape tip nozzle" and most likely am not getting sufficient air pressure. Right side caplider brakes seems to be fine (move in and out easily when clamped) and I was just going to put a kit in because it is so old. The Haynes book says to not split the caliper unless you have to. The other front caliper seems to have a stuck piston because when clamping it it will not move. I am soaking in brake fluid and will see..... Any help here? |
| Brian_Boss |
Sep 3 2012, 12:59 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
Here is a thread with a lot of good info:
brake thread Just noticed you're in Dallas too. Where in Dallas? I live near Whiterock Lake in East Dallas. Brian |
kbrunk1 How do you get Pistons Out for Front Brake Calipers Sep 3 2012, 09:50 AM
9146986 That is the correct procedure. If you have some e... Sep 3 2012, 10:04 AM
Brian_Boss If you use the search feature, Eric Shea has poste... Sep 3 2012, 10:26 AM
Bartlett 914
If you use the search feature, Eric Shea has post... Sep 3 2012, 10:44 AM
kbrunk1
If you use the search feature, Eric Shea has pos... Sep 3 2012, 11:46 AM
jcb29
There is a small hole drilled thru the spacer bl... Sep 3 2012, 12:46 PM
wingnut86 Grease gun works every time on stuck ones. Make s... Sep 3 2012, 03:40 PM
Elliot Cannon The best advice you can get is from Eric Shea. (N... Sep 3 2012, 04:05 PM
Eric_Shea For what you're up against, fluid will probabl... Sep 3 2012, 04:20 PM
kbrunk1
For what you're up against, fluid will probab... Sep 3 2012, 08:26 PM
kbrunk1
[quote name='Eric_Shea' post='1733492' date='Sep ... Sep 3 2012, 08:52 PM
euro911 Nice clip :thumbsup:
You make it all look fast a... Sep 3 2012, 08:17 PM
wingnut86 Elliot is just jealous because the word Skeet was ... Sep 3 2012, 08:31 PM
Elliot Cannon
Elliot is just jealous because the word Skeet was... Sep 3 2012, 10:11 PM
wingnut86 You send him complete ugly ones, or those with mis... Sep 3 2012, 09:35 PM
Eric_Shea We use a vibratory polisher on the pistons. Then w... Sep 3 2012, 10:52 PM
get off my lawn Using air pressure can be dangerous, a small canno... Sep 4 2012, 03:45 PM
pilothyer Grease gun and water........no muss no fuss :D Sep 5 2012, 03:36 AM
stugray I had a flat piece of 1" teflon laying around... Sep 5 2012, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 02:54 AM |
