| kbrunk1 |
Sep 3 2012, 09:50 AM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Haynes and Climer books say you clamp one side (one piston) then use air to push out the other side.
I have a small compressor. I am assuming you closed both bleed valves and then apply air to where the hydrolic line comes in. When I do this I can not get the piston to come out. Do you have to get a threaded fitting and then apply air pressure? I was just pressing a "riggged tape tip nozzle" and most likely am not getting sufficient air pressure. Right side caplider brakes seems to be fine (move in and out easily when clamped) and I was just going to put a kit in because it is so old. The Haynes book says to not split the caliper unless you have to. The other front caliper seems to have a stuck piston because when clamping it it will not move. I am soaking in brake fluid and will see..... Any help here? |
| Eric_Shea |
Sep 3 2012, 04:20 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
For what you're up against, fluid will probably be the only answer. When using a fluid like grease or water, there will be no flying parts. Fluids don't compress so they usually just plop out of the bore without much fanfare. Watch the video and you can see how it's done:
https://www.youtube.com/watch?v=WxN_iFv3CB4 I don't recommend honing bores any more. This leaves a fresh steel against fresh steel surface. If the car sits for any period of time, you will have this problem all over again but worse. In for a penny, in for a pound. I "always" recommend do it yourselfers find a local plating company and finish the job right. The plating process will clean up the caliper and add a protective layer of zinc back into the bore. Yellow dichromate is the stock color and the fasteners are black zinc. E. |
kbrunk1 How do you get Pistons Out for Front Brake Calipers Sep 3 2012, 09:50 AM
9146986 That is the correct procedure. If you have some e... Sep 3 2012, 10:04 AM
Brian_Boss If you use the search feature, Eric Shea has poste... Sep 3 2012, 10:26 AM
Bartlett 914
If you use the search feature, Eric Shea has post... Sep 3 2012, 10:44 AM
kbrunk1
If you use the search feature, Eric Shea has pos... Sep 3 2012, 11:46 AM
jcb29
There is a small hole drilled thru the spacer bl... Sep 3 2012, 12:46 PM
Brian_Boss Here is a thread with a lot of good info:
brake th... Sep 3 2012, 12:59 PM
wingnut86 Grease gun works every time on stuck ones. Make s... Sep 3 2012, 03:40 PM
Elliot Cannon The best advice you can get is from Eric Shea. (N... Sep 3 2012, 04:05 PM
kbrunk1
For what you're up against, fluid will probab... Sep 3 2012, 08:26 PM
kbrunk1
[quote name='Eric_Shea' post='1733492' date='Sep ... Sep 3 2012, 08:52 PM
euro911 Nice clip :thumbsup:
You make it all look fast a... Sep 3 2012, 08:17 PM
wingnut86 Elliot is just jealous because the word Skeet was ... Sep 3 2012, 08:31 PM
Elliot Cannon
Elliot is just jealous because the word Skeet was... Sep 3 2012, 10:11 PM
wingnut86 You send him complete ugly ones, or those with mis... Sep 3 2012, 09:35 PM
Eric_Shea We use a vibratory polisher on the pistons. Then w... Sep 3 2012, 10:52 PM
get off my lawn Using air pressure can be dangerous, a small canno... Sep 4 2012, 03:45 PM
pilothyer Grease gun and water........no muss no fuss :D Sep 5 2012, 03:36 AM
stugray I had a flat piece of 1" teflon laying around... Sep 5 2012, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 02:54 AM |
