| boiledcabbage |
Sep 4 2012, 03:17 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 23-May 05 From: Ottawa, Canada Member No.: 4,131 |
Tracking a performance problem on my stock 74 1.8 FI and would appreciate any thoughts:
Sluggish in 3rd and above and wondering if fuel is the issue. starts and idles well,good compression, recent tuneup and valve adjustment although I did it myself... 32psi at idle, 29psi at 3000rpm measured at the CSV, volume only 1.0 liter perminute, no visible kinks or bundle in the tank. Any thoughts? I will be double checking the vacuum advance and timing just in case... |
underthetire And check the mechanical advance as well. Sep 4 2012, 03:25 PM
Dave_Darling One liter per MINUTE? That sounds like a seriousl... Sep 4 2012, 04:26 PM
boiledcabbage Thanks Dave -no I really did mean 0.5l in 30 secon... Sep 4 2012, 04:30 PM
SLITS Spec is 50 - 62 L/hr .... 0.83 - 1.03 L/min .... b... Sep 4 2012, 04:53 PM
boiledcabbage
Spec is 50 - 62 L/hr .... 0.83 - 1.03 L/min .... ... Sep 4 2012, 05:08 PM
Dave_Darling Crap, I had the units wrong! Thanks for check... Sep 4 2012, 08:24 PM
kg6dxn I once had a fuel filter with a blockage that woul... Sep 4 2012, 09:04 PM
pilothyer Although your fuel pressure regulator seems to be ... Sep 4 2012, 09:39 PM
boiledcabbage
Although your fuel pressure regulator seems to be... Sep 6 2012, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 02:25 AM |
