| Matt Romanowski |
Sep 5 2012, 01:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I've done tons of searching, but I haven't been able to find if anyone knows the coefficient of lift for a 914? I've found lots of Cd and Ca numbers, but I need the Cl for some data work.
Thanks! |
| stugray |
Sep 5 2012, 03:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE CL = Coefficient of lift , which is determined by the type of airfoil and angle of attack. Well I sure hope that the lift comes out to be a negative number in all cases for a street car. Now a formula-1 going 180MPH and coming over a rise is a little different.... I dont believe that these calculations will apply to our cars because of the ground effect. We should have a vacuum under our cars at speed. A free-flying aircraft does not experience ground effect until feet from the ground. And in that case it works opposite to the ground effect of a vehicle (it helps to hold it OFF the ground) Stu |
Matt Romanowski Coefficient of Lift Sep 5 2012, 01:17 PM
ThePaintedMan Have you seen this site?
http://www.cassidy-onli... Sep 5 2012, 01:50 PM
Matt Romanowski
http://www.cassidy-onl... Sep 5 2012, 02:15 PM
ThePaintedMan Could you take the 124.76 N he calculated for the ... Sep 5 2012, 02:29 PM
Matt Romanowski
Could you take the 124.76 N he calculated for the... Sep 5 2012, 02:32 PM
Dave_Darling It's not the frontal area, it's the planfo... Sep 5 2012, 02:44 PM
Dave_Darling Actually, almost all cars generate positive lift a... Sep 5 2012, 11:54 PM
mittelmotor
Actually, almost all cars generate positive lift ... Sep 6 2012, 12:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:38 PM |
