Performance axle kit |
moggy |
Sep 3 2012, 02:19 PM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
Hi guys
In the last rally 2 other Porsche's (911's) went out because their CVs failed. My standard 914-4 ones have now lasted me the past 3 years, but I think I'm on borrowed time. Also, I checked the play and they're excessive, so they're on their way out that's for sure. I was wondering if anyone has experience of these: http://www.pelicanparts.com/cgi-bin/smart/...36%29%2C%20Each (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-3285-1346703546.1.jpg) I need them to put up with 200bhp/lbft engine and a whole load of abuse (IMG:style_emoticons/default/happy11.gif) I think these will do nicely but thought I'd get a second opinion from here from anyone that's tried them. Cheers Moggy |
Randal |
Sep 4 2012, 09:15 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Hi guys In the last rally 2 other Porsche's (911's) went out because their CVs failed. My standard 914-4 ones have now lasted me the past 3 years, but I think I'm on borrowed time. Also, I checked the play and they're excessive, so they're on their way out that's for sure. I was wondering if anyone has experience of these: http://www.pelicanparts.com/cgi-bin/smart/...36%29%2C%20Each (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-3285-1346703546.1.jpg) I need them to put up with 200bhp/lbft engine and a whole load of abuse (IMG:style_emoticons/default/happy11.gif) I think these will do nicely but thought I'd get a second opinion from here from anyone that's tried them. Cheers Moggy My brand new ones only lasted 3 events, but we do excessive things at launch for sure. I went with the 944 turbo CV, but you need to change the output shaft on the 901 and a few other bits, but these will not break. Andy had a great posting going through the numbers of what you to do to swap them over. Just search for CV's and I think you will find the link. If I remember right the output shaft is one from a old 911 (901) that has a different spline to match 944 turbo CV's. It also seems like I only changed the output shaft and the CV's, didn't have to change anything else, but maybe had to do a bit of machining on the stock drive shaft. |
smj |
Sep 6 2012, 11:43 AM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
I went with the 944 turbo CV, but you need to change the output shaft on the 901 and a few other bits, but these will not break. Quick question about that: it looks like you should be able to swap the output flanges w/o opening up the box - true? I figured it would at least need to be drained of oil, but I don't really see any seals in the PET. Should/can the taper bearing (part 8, page 132) also be replaced at that time? Or at least checked and repacked...? If I remember right the output shaft is one from a old 911 (901) that has a different spline to match 944 turbo CV's. It also seems like I only changed the output shaft and the CV's, didn't have to change anything else, but maybe had to do a bit of machining on the stock drive shaft. The thread you linked to mentions the 4mm of machining on each end of the drive shaft - and that thread or this one talk about the Sway-A-Way floating drive shafts. There's a list of output flanges, CV joints, stub axles, and wheel hub part numbers on this here wiki if you're going crazy looking for which parts ought to fit together. |
Randal |
Sep 6 2012, 02:50 PM
I went with the 944 turbo CV, but you need to change the output shaft on the 901 and a few other bits, but these will not break. Quick question about that: it looks like you should be able to swap the output flanges w/o opening up the box - true? I figured it would at least need to be drained of oil, but I don't really see any seals in the PET. Should/can the taper bearing (part 8, page 132) also be replaced at that time? Or at least checked and repacked...? If I remember right the output shaft is one from a old 911 (901) that has a different spline to match 944 turbo CV's. It also seems like I only changed the output shaft and the CV's, didn't have to change anything else, but maybe had to do a bit of machining on the stock drive shaft. The thread you linked to mentions the 4mm of machining on each end of the drive shaft - and that thread or this one talk about the Sway-A-Way floating drive shafts. There's a list of output flanges, CV joints, stub axles, and wheel hub part numbers on this here wiki if you're going crazy looking for which parts ought to fit together. Changing the output shaft on the 901 is really easy. Just be sure you have the correct torque specs. I drained a bit of oil, later to be reused, then changed the shafts and didn't spill any oil. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:49 PM |
