| tornik550 |
Sep 5 2012, 08:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am working on getting my idle jets correct. My mains seem ok.
At idle (800 rpm) I am getting a reasonable air fuel ratio (14.8 using innovate a/f gauge). I'm using 50 size idles. If I slightly press and hold the peddle to a steady 1200 to 2000 rpm the a/f goes to 19. The car drives like crap until I reach 2000 rpm when the main jets kick in- at the same time the a/f ratio goes to 14 or so. What adjustments can I make that will leave idle at the same mixture however rich up the mixture til about 2000 rpms? I thought that was mainly idle just only? I did try to increase the idle jet size to 55. The idle mixture goes down to 11.8 at 800rpm and is perfect between 1200 to 2000 rpm. Confused- I can either get the idle correct OR the low rpms? I have followed weber's info on best lean each time I switched jets. Ideas? What am I missing- i'm sure its something simple. |
| tornik550 |
Sep 6 2012, 04:39 PM
I don't understand how I can Make the mixture richer at 1200 rpm while keeping the mixture the same at idle (800rpm)?
| mrbubblehead |
Sep 6 2012, 04:45 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I don't understand how I can Make the mixture richer at 1200 rpm while keeping the mixture the same at idle (800rpm)? you dont want the mixture to be richer at 1200 rpm you want it to be leaner. you want your idle/progressive circuit to be as lean as the engine will let you. your mains are what you want to be rich. 12.5 A/F. a lean idle progressive circuit will run cooler and yield the best gas mileage. |
tornik550 Weber 44 IDF mixture help needed Sep 5 2012, 08:11 PM
mrbubblehead it sounds like your close. does the car sputter an... Sep 5 2012, 08:20 PM
tornik550
it sounds like your close. does the car sputter a... Sep 5 2012, 08:49 PM
cgnj Hi,
What size motor, What size vent are you runni... Sep 5 2012, 08:35 PM
mrbubblehead your idle/progressive circuit is behaving exactly ... Sep 6 2012, 04:48 PM
toolguy The idle jets set the mixture for progression hole... Sep 6 2012, 05:48 PM
tornik550 I increased my idle jet size to 55. Now the engin... Sep 6 2012, 06:49 PM
toolguy How does it run when it's cold and just starte... Sep 7 2012, 10:34 AM
tornik550
How does it run when it's cold and just start... Sep 7 2012, 09:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 11:34 PM |
