vanagon fan shroud, poor timing? |
vitis |
Sep 6 2012, 06:19 PM
Newbie Group: Members Posts: 9 Joined: 31-December 11 From: Clover, Virginia Member No.: 13,952 Region Association: MidAtlantic Region |
Curious if anyone is using a vanagon fan shroud on their type IV motor. Got the tip from Blake Meredith as it doesn't have those lower wings on the shroud so it should cool the race motor a little better but....once I found one and got it home I realized that the casting did not have the normal hole in the top for checking the timing. So should I drill out the part of the casting in the fan shroud to expose the timing marks? Should I figure out some way of tapping threads in that new hole to screw the cover from a 914 shroud in the defect? I figure that hole will just be a great way of releasing those cooling vapors that I consider so valuable.
Thanks, Milt McPherson |
bam914 |
Sep 6 2012, 08:51 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
So I forgot to respond to your email. When I had mine I ran Electromotive ignition. On that system you can use a voltmeter to set timing and that is what I did. You can use the timing scale for a bus that mounts on the shroud. On a bus fan the alt pulley has a timing mark on it. This is not hard to duplicate. You could also ask Len since he ran one on his car and ran a Mallory dist.
Lo-Fi Version | Time is now: 15th June 2024 - 07:07 PM |
