| tornik550 |
Sep 5 2012, 08:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am working on getting my idle jets correct. My mains seem ok.
At idle (800 rpm) I am getting a reasonable air fuel ratio (14.8 using innovate a/f gauge). I'm using 50 size idles. If I slightly press and hold the peddle to a steady 1200 to 2000 rpm the a/f goes to 19. The car drives like crap until I reach 2000 rpm when the main jets kick in- at the same time the a/f ratio goes to 14 or so. What adjustments can I make that will leave idle at the same mixture however rich up the mixture til about 2000 rpms? I thought that was mainly idle just only? I did try to increase the idle jet size to 55. The idle mixture goes down to 11.8 at 800rpm and is perfect between 1200 to 2000 rpm. Confused- I can either get the idle correct OR the low rpms? I have followed weber's info on best lean each time I switched jets. Ideas? What am I missing- i'm sure its something simple. |
| toolguy |
Sep 7 2012, 10:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
How does it run when it's cold and just started? a bunch of 'sneezing' and popping? That's usually the sign of the idle mixture too lean. . If it starts and idles fine cold , I'd leave it alone, but if it's burping, see if backing the idle mixture screws all out 1/2 turn fattens your idle readings. .
Do all the mixture screws make a change? are they all approximately turned out the same amount ? 1-2 turns ? If they are 3 or so turns out, then the idle jets may still be too small. . What do the plugs look like? |
tornik550 Weber 44 IDF mixture help needed Sep 5 2012, 08:11 PM
mrbubblehead it sounds like your close. does the car sputter an... Sep 5 2012, 08:20 PM
tornik550
it sounds like your close. does the car sputter a... Sep 5 2012, 08:49 PM
cgnj Hi,
What size motor, What size vent are you runni... Sep 5 2012, 08:35 PM
tornik550 I don't understand how I can Make the mixture ... Sep 6 2012, 04:39 PM
mrbubblehead
I don't understand how I can Make the mixture... Sep 6 2012, 04:45 PM
mrbubblehead your idle/progressive circuit is behaving exactly ... Sep 6 2012, 04:48 PM
toolguy The idle jets set the mixture for progression hole... Sep 6 2012, 05:48 PM
tornik550 I increased my idle jet size to 55. Now the engin... Sep 6 2012, 06:49 PM
tornik550
How does it run when it's cold and just start... Sep 7 2012, 09:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 11:36 PM |
