> Wobbly steering wheel
moggy
post Sep 2 2012, 02:20 PM
My steering wheel has been developing a wobble over the past few years, now it's time to do something about it. I've ruled out the steering wheel itself. The steering wheel wobbles up and down. as if it's loose I've heard there's a bearing that's a common item that causes this, but looking at the Pelican Parts site its not clear to me which one.
http://www.pelicanparts.com/catalog/shopca...r_pg2.htm#item9
The above link shows the following parts:
Upper steering column bushing repair sleeve
Inner steering shaft bearing
Upper steering shaft bearing
Lower shaft bearing
Steering column split ring bushing
Pressure spring in sttering shaft
Initially I went in to buy a steering bearing now I'm totally confused (IMG:style_emoticons/default/confused24.gif) what do I need to buy?
chuckc
post Sep 7 2012, 06:55 AM
QUOTE(moggy @ Sep 2 2012, 04:20 PM) *
I fixed mine earlier this year. here is the link. hope it helps.
peace,
Chuck
http://www.914world.com/bbs2/index.php?sho...=182321&hl=
rwilner
post Sep 7 2012, 11:36 AM
No Ghosts in the Machine
I used this bushing to repair this exact issue on my 84 carrera, which is the same steering column I think. It's a 15 minute job with an impact gun, add 15 minutes if you have to do the dual lever thing to get the steering wheel nut loosened.
- Lo-Fi Version Time is now: 5th March 2026 - 12:54 AM
