| pnewman |
Aug 18 2012, 10:08 PM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
Ok Ok Ok.
I have to many gadgets in my car for a 75 amp alternator to support. They all work great but they are pigs: Heated seats high power stereo Sub woofer w/ amp HID headlights windshield washer pump Interior / map lights in rear view mirror etc. So I have a seperate circuit and an electrical sub-panel to support the load safely but simply put: "I need more power Scotty!" Took my old 50 amp Bosch to an alternator / starter rebuilder and after looking at it a bit they recommended the AC Delco 100 / 105+ amp single wire alternator with integral regulator for $110 rebuilt. He stated that it could run the dash idiot light too. Not quite ready to bypass the voltage regulator etc. I am sure this mod is probably old hat for some. Thoughts? Thanks in advance, (IMG:style_emoticons/default/driving-girl.gif) Pete |
| Matt Meyer |
Aug 22 2012, 02:28 PM
Überlurker ![]() ![]() Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
I don't see why you would ever run a one wire setup.
This is for a different vehicle but here is a link to a discussion on one vs. three wire connection and converting from a externally regulated alternator to an internally regulated alternator. Bob Skelly's Alternator Site The CS series alternators and the 12SI series are supposed to have excellent cooling. What would you use for a pulley? I think these typically spin at about 1/2 engine speed. The pulley on the fan is pretty big which means you should have a big pulley on the alternator. The pulleys on modern alternators are pretty small. Maybe they are suppposed to spin faster. |
| pnewman |
Sep 8 2012, 12:10 PM
I don't see why you would ever run a one wire setup. This is for a different vehicle but here is a link to a discussion on one vs. three wire connection and converting from a externally regulated alternator to an internally regulated alternator. Bob Skelly's Alternator Site The CS series alternators and the 12SI series are supposed to have excellent cooling. What would you use for a pulley? I think these typically spin at about 1/2 engine speed. The pulley on the fan is pretty big which means you should have a big pulley on the alternator. The pulleys on modern alternators are pretty small. Maybe they are suppposed to spin faster. I spoke with an alternator / starter rebuilder and he was trying to pitch the GM unit. One of his pitched pro's was it's smaller pulley which he stated: will provide higher alternator rpm at idle; giving you more current at idle which is a shortcoming of larger pullied units. (IMG:style_emoticons/default/idea.gif) |
pnewman Alternator upping amperage suggestions Aug 18 2012, 10:08 PM
GeorgeRud It really should just come down to whether the Del... Aug 19 2012, 06:51 AM
ArtechnikA
HID headlights
HID's actually consume less c... Aug 19 2012, 07:35 AM
kg6dxn I think you should go with the GM alternator. I ru... Aug 19 2012, 09:30 AM
jsayre914
I think you should go with the GM alternator. I r... Aug 19 2012, 01:43 PM
pnewman
I think you should go with the GM alternator. I ... Aug 21 2012, 10:49 PM
jsayre914
I like the idea of having a modified or rewound ... Aug 22 2012, 02:06 PM
pnewman I am concerned about the cleanlyness and reliabili... Aug 21 2012, 10:51 PM
pnewman
I think you should go with the GM alternator. I r... Aug 21 2012, 10:52 PM
kg6dxn
PLEASE SHOW US SOME PICS OF HOW YOU FIT AND SET I... Aug 23 2012, 02:29 PM
jsayre914
Don't get too excited... I don't have a ... Aug 23 2012, 03:30 PM
dlestep
The world realized this and chose Tesla's AC... Aug 22 2012, 02:12 PM
ArtechnikA
[quote name='kg6dxn' post='1725857' date='Aug 19 ... Aug 22 2012, 02:16 PM
dlestep
[quote name='dlestep' post='1727599' date='Aug 22... Aug 22 2012, 07:24 PM
pnewman
I think you should go with the GM alternator. I r... Sep 8 2012, 12:32 PM
Rod Interested in this too.
A friend of mine has just... Aug 22 2012, 10:31 AM
balljoint davep was building higher output alternators. Try... Aug 22 2012, 01:32 PM
pnewman
davep was building higher output alternators. Tr... Sep 8 2012, 01:21 PM
ArtechnikA
Which leads us to the inevitable question - how d... Aug 22 2012, 02:14 PM
jsayre914
Which leads us to the inevitable question - how d... Aug 22 2012, 02:53 PM
damesandhotrods [quote name='pnewman' date='Aug 18 201... Aug 22 2012, 02:34 PM
Bartlett 914
[quote name='pnewman' date='Aug 18 20... Aug 22 2012, 03:07 PM
pnewman
Ok Ok Ok.
I have to many gadgets in my car for... Sep 8 2012, 12:07 PM
damesandhotrods Then why not install an amp meter and monitor your... Aug 22 2012, 07:20 PM
pnewman
Then why not install an amp meter and monitor you... Sep 8 2012, 12:21 PM
kg6dxn The smaller pulley will rob 1-2hp due to spinning ... Sep 8 2012, 12:18 PM
02loftsmoor I thought sports cars didn't have all that FLU... Sep 8 2012, 11:23 PM
pnewman
I thought sports cars didn't have all that FL... Sep 9 2012, 01:22 PM
balljoint
I thought sports cars didn't have all that F... Oct 5 2012, 11:54 AM
tim_nd When you upgrade to this one wire, can I have your... Sep 9 2012, 12:16 AM
jockellis In the mid '70s, the owner of a Waycross, GA V... Sep 9 2012, 06:56 AM
ArtechnikA Wire costs something and it weighs something.
When... Sep 9 2012, 07:15 AM
pnewman [b]I have an upgraded 105 amp alternator now with ... Oct 5 2012, 11:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:43 AM |
