| pnewman |
Aug 18 2012, 10:08 PM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
Ok Ok Ok.
I have to many gadgets in my car for a 75 amp alternator to support. They all work great but they are pigs: Heated seats high power stereo Sub woofer w/ amp HID headlights windshield washer pump Interior / map lights in rear view mirror etc. So I have a seperate circuit and an electrical sub-panel to support the load safely but simply put: "I need more power Scotty!" Took my old 50 amp Bosch to an alternator / starter rebuilder and after looking at it a bit they recommended the AC Delco 100 / 105+ amp single wire alternator with integral regulator for $110 rebuilt. He stated that it could run the dash idiot light too. Not quite ready to bypass the voltage regulator etc. I am sure this mod is probably old hat for some. Thoughts? Thanks in advance, (IMG:style_emoticons/default/driving-girl.gif) Pete |
| damesandhotrods |
Aug 22 2012, 07:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
Then why not install an amp meter and monitor your current draw? I don’t mean to get all Myth Busters on you, but if you don’t know, you’ll never feel confident in the car.
This also gets into your switches. If your devices are wired through the switches and they can’t handle the current you’re looking at a potential fire. If you’re drawing so much current the switches should be controlling relays and the relays handling the current. |
| pnewman |
Sep 8 2012, 12:21 PM
Then why not install an amp meter and monitor your current draw? I don’t mean to get all Myth Busters on you, but if you don’t know, you’ll never feel confident in the car. This also gets into your switches. If your devices are wired through the switches and they can’t handle the current you’re looking at a potential fire. If you’re drawing so much current the switches should be controlling relays and the relays handling the current. Ammeter: I see a "voltage drop" on my voltmeter. The issue is obvious with usage of multiple accessories when used simultaneously. Fire Hazard: I created a secondary (sub ATC fuse panel) with its' own main back to the battery which is also routed through a main fuse at the battery. Said panel is triggered off of a relay triggered by the ignition switch. The relay/wires/fuses etc all are good for their respective loads. Oh and I have been a full time FireFighter for 12+ years. Kind of watchful of those risks. So much so that I have an extinguisher mounted at the ready. |
pnewman Alternator upping amperage suggestions Aug 18 2012, 10:08 PM
GeorgeRud It really should just come down to whether the Del... Aug 19 2012, 06:51 AM
ArtechnikA
HID headlights
HID's actually consume less c... Aug 19 2012, 07:35 AM
kg6dxn I think you should go with the GM alternator. I ru... Aug 19 2012, 09:30 AM
jsayre914
I think you should go with the GM alternator. I r... Aug 19 2012, 01:43 PM
pnewman
I think you should go with the GM alternator. I ... Aug 21 2012, 10:49 PM
jsayre914
I like the idea of having a modified or rewound ... Aug 22 2012, 02:06 PM
pnewman I am concerned about the cleanlyness and reliabili... Aug 21 2012, 10:51 PM
pnewman
I think you should go with the GM alternator. I r... Aug 21 2012, 10:52 PM
kg6dxn
PLEASE SHOW US SOME PICS OF HOW YOU FIT AND SET I... Aug 23 2012, 02:29 PM
jsayre914
Don't get too excited... I don't have a ... Aug 23 2012, 03:30 PM
dlestep
The world realized this and chose Tesla's AC... Aug 22 2012, 02:12 PM
ArtechnikA
[quote name='kg6dxn' post='1725857' date='Aug 19 ... Aug 22 2012, 02:16 PM
dlestep
[quote name='dlestep' post='1727599' date='Aug 22... Aug 22 2012, 07:24 PM
pnewman
I think you should go with the GM alternator. I r... Sep 8 2012, 12:32 PM
Rod Interested in this too.
A friend of mine has just... Aug 22 2012, 10:31 AM
balljoint davep was building higher output alternators. Try... Aug 22 2012, 01:32 PM
pnewman
davep was building higher output alternators. Tr... Sep 8 2012, 01:21 PM
ArtechnikA
Which leads us to the inevitable question - how d... Aug 22 2012, 02:14 PM
jsayre914
Which leads us to the inevitable question - how d... Aug 22 2012, 02:53 PM
Matt Meyer I don't see why you would ever run a one wire ... Aug 22 2012, 02:28 PM
pnewman
I don't see why you would ever run a one wire... Sep 8 2012, 12:10 PM
damesandhotrods [quote name='pnewman' date='Aug 18 201... Aug 22 2012, 02:34 PM
Bartlett 914
[quote name='pnewman' date='Aug 18 20... Aug 22 2012, 03:07 PM
pnewman
Ok Ok Ok.
I have to many gadgets in my car for... Sep 8 2012, 12:07 PM
kg6dxn The smaller pulley will rob 1-2hp due to spinning ... Sep 8 2012, 12:18 PM
02loftsmoor I thought sports cars didn't have all that FLU... Sep 8 2012, 11:23 PM
pnewman
I thought sports cars didn't have all that FL... Sep 9 2012, 01:22 PM
balljoint
I thought sports cars didn't have all that F... Oct 5 2012, 11:54 AM
tim_nd When you upgrade to this one wire, can I have your... Sep 9 2012, 12:16 AM
jockellis In the mid '70s, the owner of a Waycross, GA V... Sep 9 2012, 06:56 AM
ArtechnikA Wire costs something and it weighs something.
When... Sep 9 2012, 07:15 AM
pnewman [b]I have an upgraded 105 amp alternator now with ... Oct 5 2012, 11:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:43 AM |
