GB- CV joint bolts drilled for safety wire, $2.25 each GB Closes Nov 15th |
Mikey914 |
Aug 12 2012, 07:17 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are new, and drilled for safety wire. The beauty is that you don't have to replace all the bolts, so if you want piece of mind that your CV joints will not come off, you can safety wire the bolts on. This will make it much easier.
Who needs em? Attached thumbnail(s) Attached image(s) |
Dr Evil |
Aug 13 2012, 09:04 PM
4 is the preferred method (IMG:style_emoticons/default/smile.gif)
bigkensteele |
Aug 13 2012, 09:31 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Why? If wired correctly, the orientation of the holes should not matter, no? (IMG:style_emoticons/default/confused24.gif) Mark, I am in for a set of 16 as well. I can send you back new 16 cores, too. Is there any reason that used bolts can't be used as cores? |
Mikey914 |
Sep 8 2012, 10:40 PM
Why? If wired correctly, the orientation of the holes should not matter, no? (IMG:style_emoticons/default/confused24.gif) Mark, I am in for a set of 16 as well. I can send you back new 16 cores, too. Is there any reason that used bolts can't be used as cores? More hassle to clean up and the finish can be an issue. Easier to buy new ones at $1.60 each than mess with the old ones. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:20 PM |
