> Floor mat clip options / suggestions taken. Process complete. Come in and take a look! :-D, Sliding floor mats annoyed me. Ended up fabricating from scratch. Take a Look.
pnewman
post Sep 12 2012, 11:20 AM
So I have some nice looking floor mats. They sit on top of my carpeting. Only one small problem; after a while of driving they begin to bunch up on the accelerator pedal and keep my idle up. (IMG:style_emoticons/default/mad.gif) (See first / top pic)
I keep having to reach down under the front of my seat and pull them back.
They have grommets for keepers but they don't line up with the stock pegs. (See middle pic) I was hoping to utilize the stock pegs. I have seen aftermarket generic clips (see Last / bottom pic). I was hoping to utilize the stock pegs...
I was hoping that someone else has solved this problem and could make recommendations so as to avoid a trial and error experience for myself.
Thanks in advance for the assistance.
Pete (IMG:style_emoticons/default/smile.gif)
wingnut86
post Sep 12 2012, 12:19 PM
...boola la boo boola boo...
Check JC Whitney. They used to have the oddball offerings similar to this. Also, some OEMs used to make extended carpet pins that also rotated 360° (don't know why) and had the modern hook type pin. You may have to call a auto carpet retailer to see wgat they know. Lastly, hit a pick'n'pull or similar and see what the donor cars of different makes have...
pnewman
post Sep 12 2012, 02:51 PM
QUOTE(wingnut86 @ Sep 12 2012, 10:19 AM) *
Check JC Whitney. They used to have the oddball offerings similar to this. Also, some OEMs used to make extended carpet pins that also rotated 360°[u] (don't know why) and had the modern hook type pin. You may have to call a auto carpet retailer to see wgat they know. Lastly, hit a pick'n'pull or similar and see what the donor cars of different makes have...
The extending post type is something that I have seen before that I thought might work. I can't remember where however (IMG:style_emoticons/default/confused24.gif) rrrrr. Last resort is a U-pic-a-part.
pnewman   Floor mat clip options / suggestions taken. Process complete. Come in and take a look! :-D   Sep 12 2012, 11:20 AM
wingnut86   Check JC Whitney. They used to have the oddball o...   Sep 12 2012, 12:19 PM
pnewman   Check JC Whitney. They used to have the oddball ...   Sep 12 2012, 02:51 PM
DBCooper   Someone here sewed or glued a yoga mat (they come ...   Sep 12 2012, 03:40 PM
pnewman   found a newby ebay seller from Greece with a good ...   Sep 12 2012, 10:46 PM
pnewman   I am considering a carpet screw specialty rivot. s...   Sep 12 2012, 10:51 PM
Mikey914   I'm not real fond of anything that puts a hole...   Sep 12 2012, 10:57 PM
pnewman   I'm not real fond of anything that puts a hol...   Sep 13 2012, 07:37 AM
blitZ   I made my own with a piece of coat hanger. I made...   Sep 13 2012, 05:19 AM
pnewman   I made my own with a piece of coat hanger. I mad...   Sep 13 2012, 07:34 AM
pnewman   I made my own with a piece of coat hanger. I mad...   Oct 8 2012, 08:52 AM
wingnut86   I do like the solutions you found, especially the ...   Sep 13 2012, 05:30 AM
Bartlett 914   So I have some nice looking floor mats. They sit...   Sep 13 2012, 07:17 AM
pnewman   [quote name='pnewman' post='1738091' date='Sep 12...   Sep 13 2012, 07:31 AM
rhodyguy   some stick on velcro? k   Sep 13 2012, 08:51 AM
Mikey914   some stick on velcro? k That's what I use. ...   Sep 13 2012, 10:37 AM
dlestep   some stick on velcro? k That's what I use....   Sep 13 2012, 11:32 AM
Eric_Shea   I have an idea from the music industry. Strap lock...   Oct 8 2012, 08:51 PM
pnewman   I have an idea from the music industry. Strap loc...   Oct 8 2012, 09:42 PM
cary   some stick on velcro? k That's what I use....   Oct 8 2012, 10:26 PM
pnewman   [quote name='Mikey914' post='1738610' date='Sep 1...   Oct 9 2012, 09:01 AM
rhodyguy   staple the velcro to the carpet. the holes will ne...   Oct 9 2012, 10:35 AM
Eric_Shea   That's not the strap lock I was thinking of. T...   Oct 9 2012, 08:13 PM
Eric_Shea   Here it is... make the hole big enough to fit over...   Oct 9 2012, 09:00 PM
pnewman   Here it is... make the hole big enough to fit ove...   Oct 9 2012, 09:52 PM
pnewman   Anyhow. Here is what I have made and am currently...   Oct 9 2012, 10:03 PM
pnewman   twisted wire to design   Oct 9 2012, 10:06 PM
pnewman   cut off excess & create loops   Oct 9 2012, 10:07 PM
pnewman   weld shut loops then grind, wire wheel & media...   Oct 9 2012, 10:09 PM
pnewman   primed, painted then used heat shrink tubing @ hoo...   Oct 9 2012, 10:13 PM
pnewman   finally installed with #10 x 1/2" stainless s...   Oct 9 2012, 10:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:17 PM
