| pnewman |
Sep 12 2012, 11:20 AM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
So I have some nice looking floor mats. They sit on top of my carpeting. Only one small problem; after a while of driving they begin to bunch up on the accelerator pedal and keep my idle up. (IMG:style_emoticons/default/mad.gif) (See first / top pic)
I keep having to reach down under the front of my seat and pull them back. They have grommets for keepers but they don't line up with the stock pegs. (See middle pic) I was hoping to utilize the stock pegs. I have seen aftermarket generic clips (see Last / bottom pic). I was hoping to utilize the stock pegs... I was hoping that someone else has solved this problem and could make recommendations so as to avoid a trial and error experience for myself. Thanks in advance for the assistance. Pete (IMG:style_emoticons/default/smile.gif) Attached image(s)
| Mikey914 |
Sep 12 2012, 10:57 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I'm not real fond of anything that puts a hole throught the tar and metal. Any water penetration will have an opening to beneath the tar.
There has to be a better way. |
| pnewman |
Sep 13 2012, 07:37 AM
I'm not real fond of anything that puts a hole throught the tar and metal. Any water penetration will have an opening to beneath the tar. There has to be a better way. I couldn't agree more. I am definately NOT drilling a hole in my solid floor pans to secure floor a pair of floor mats! That is definately not a good idea. (IMG:style_emoticons/default/dry.gif) I do think however that the "pin screws" shown (the little specialty grommets with philips heads and plastic screw shanks below) would only screw into the carpet and rubber beneath and not through the metal floor. ...I think. |
pnewman Floor mat clip options / suggestions taken. Process complete. Come in and take a look! :-D Sep 12 2012, 11:20 AM
wingnut86 Check JC Whitney. They used to have the oddball o... Sep 12 2012, 12:19 PM
pnewman
Check JC Whitney. They used to have the oddball ... Sep 12 2012, 02:51 PM
DBCooper Someone here sewed or glued a yoga mat (they come ... Sep 12 2012, 03:40 PM
pnewman found a newby ebay seller from Greece with a good ... Sep 12 2012, 10:46 PM
pnewman I am considering a carpet screw specialty rivot. s... Sep 12 2012, 10:51 PM
blitZ I made my own with a piece of coat hanger. I made... Sep 13 2012, 05:19 AM
pnewman
I made my own with a piece of coat hanger. I mad... Sep 13 2012, 07:34 AM
pnewman
I made my own with a piece of coat hanger. I mad... Oct 8 2012, 08:52 AM
wingnut86 I do like the solutions you found, especially the ... Sep 13 2012, 05:30 AM
Bartlett 914
So I have some nice looking floor mats. They sit... Sep 13 2012, 07:17 AM
pnewman
[quote name='pnewman' post='1738091' date='Sep 12... Sep 13 2012, 07:31 AM
rhodyguy some stick on velcro?
k Sep 13 2012, 08:51 AM
Mikey914
k
That's what I use. ... Sep 13 2012, 10:37 AM
dlestep
k
That's what I use.... Sep 13 2012, 11:32 AM
Eric_Shea I have an idea from the music industry. Strap lock... Oct 8 2012, 08:51 PM
pnewman
I have an idea from the music industry. Strap loc... Oct 8 2012, 09:42 PM
cary
k
That's what I use.... Oct 8 2012, 10:26 PM
pnewman
[quote name='Mikey914' post='1738610' date='Sep 1... Oct 9 2012, 09:01 AM
rhodyguy staple the velcro to the carpet. the holes will ne... Oct 9 2012, 10:35 AM
Eric_Shea That's not the strap lock I was thinking of. T... Oct 9 2012, 08:13 PM
Eric_Shea Here it is... make the hole big enough to fit over... Oct 9 2012, 09:00 PM
pnewman
Here it is... make the hole big enough to fit ove... Oct 9 2012, 09:52 PM
pnewman Anyhow. Here is what I have made and am currently... Oct 9 2012, 10:03 PM
pnewman twisted wire to design Oct 9 2012, 10:06 PM
pnewman cut off excess & create loops Oct 9 2012, 10:07 PM
pnewman weld shut loops then grind, wire wheel & media... Oct 9 2012, 10:09 PM
pnewman primed, painted
then used heat shrink tubing @ hoo... Oct 9 2012, 10:13 PM
pnewman finally installed with #10 x 1/2" stainless s... Oct 9 2012, 10:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:17 PM |
