Best paint to use, Plan on following directions exactly |
Randal |
Sep 13 2012, 12:35 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Painting my rear flares this weekend.
Which paint have you used that worked according to instructions? IMHO would rather pay more and have it work, than to be disappointed with the results and have to do it over. Appreciate all advice. Plan on doing a base coat, then clear. The flares are fiberglass. |
scotty b |
Sep 13 2012, 06:39 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
ask 20 chefs what the best way to prepare a steak is.
Best Paint ?? Glasurit, Spies Hecker, Standox will be the tops, but they aren't cheap, and no matter how wonderful the paint is, the painter will make all the difference. The biggest differences in cheap paints and expensive paitns break down into two things. 1: Cea paints use fewer pigments to create a colo. For example, to create guards red, Nason ( cheap ) may only use 3 pigments to achieve the final color whereas Spies will use 7 pigments to achieve the final color. Whereas the higher end paints will be a closer match to the TRUE color. This makes a difference in a high end high value job, and also in future repairs. 2: solid content. Cheap paints ( clears ) use a lot of solvents and binders that evaporate as the paint is applied and dries. The higher end paints use more actual solid paint. They take fewer coats, they set up better, they buff out to a better shine. I tell people it is like comparing skim milk to whole milk. There is a NOTICABLE difference in weight between a gallon of cheap clear and a gallon of expensive clear. Remember with anything, the prep work and skills are the biggest factor. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:29 PM |
