Question on Fuel Pressure D-Jet |
Strudelwagon |
Sep 17 2012, 01:52 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
Ok, I have a 74-2.0 still injected and wanted to know how critical the exact 29psi is? If I was like 30 or 31 lets say....would it run rich? or if I was 27 or 28psi...you get the idea.
My gauge shows just a hair above 30psi....should I care? Thanks SW |
Dave_Darling |
Sep 17 2012, 04:02 PM
I think the spray pattern changes at some point as well. It definitely does on the low side; at low enough pressure it will dribble rather than spray.
Higher pressures supposedly can lead to injector leaks earlier than the standard pressure. No real idea on what exact numbers are "low enough" or "too high", though. --DD |
Lo-Fi Version | Time is now: 11th June 2024 - 10:32 PM |
