> Help with rear trailing arm bolts
sixaddict
post Sep 21 2012, 10:53 AM
Car was aligned and corner balanced .....At track discoverd 3 bolts attaching @ front of trailing arm were "tight" yet arm was shifting. So bolts are tight but arm sliding back and forth....Really "interesting" under heavy braking after high speed straight...... (IMG:style_emoticons/default/evilgrin.gif)
I am sure someone can tell me what is up and how to fix..
Thanks
Terry
Eric_Shea
post Sep 21 2012, 01:46 PM
PMB Performance
Shims (washers) between the arm and it's mount until it won't move laterally any more.
That would change his camber.
Chris is on to something; There is supposed to be a plate under the bolt heads. It's rather thick. If it's missing the threaded portion of the fastener could be bottoming out prior to the assembly being tightened properly.
- Lo-Fi Version Time is now: 1st August 2025 - 02:48 PM
