> Backfires while idling after checking compression
ndtman
post Sep 23 2012, 04:37 PM
I have a 76 2.0 with the stock fuel injection that I am bring back to life. It ran fine, but I decided to check the compression. After doing this, the car now backfires a lot while idling (every 2-5 seconds), and even more so if I dare throttle up. With the dual exhaust mufler, I note that the backfiring is coming from cylinders 1 or 2. I swapped out both plugs and wires on 1 and 2, but the problem remains. All the spark plug wires are routed to the correct cylinder.
I found that if I disconnected the spark plug wire to cylinder 4, the car would not backfire, and ran smoothly. Replacing the #4 plug and wire didn't fix the problem.
I plan to replace all the plugs, wires, distributor cap, etc, but was wondering why my testing is giving such confusing results. Bottom line - the only way I can fix the backfiring at idle is to disconnect the #4 plug wire.
Any ideas? Thanks.
post Sep 23 2012, 05:39 PM
do you have a sticking valve?
Edit: you didn't cross the injector wires on 3 and 4 did you?
Mike Bellis
post Sep 23 2012, 05:58 PM
Resident Electrician
QUOTE(76-914 @ Sep 23 2012, 04:39 PM) *
Crossing the injector wire would have little effect. The 914 uses a batch fire system and not sequential injection. You would loose 1/2hp maybe. If you could measure it on a dyno.
My money is on a tight valve or carbon tracks in the distributor cap.
ndtman
post Sep 23 2012, 08:23 PM
I just checked and adjusted all the valves about a week ago. They were all very close to where they should be, and only needed minor adjustment, so I don't think it would be a tight valve. The compression was consistent across all the cylinders. I assume this means that the valves are all functioning properly.
One thing I forgot to mention was that (previously and now) with all the spark plugs hooked up, I would hear a loud puffing exhaust sound on the right underside (cylinders 3 and 4) of the car, and the exhaust was quite loud. This noise remained after I adjusted the valves. When I disconnected the spark plug on #4, this puffing quit, and the exhaust noise quieted down. I am thinking this might be a loose or leaking exhaust on #4. Any ideas?
- Lo-Fi Version Time is now: 12th March 2026 - 12:29 PM
