> 914 with Carbs, Suggestions for the return fuel line
porkchopexpress
post Sep 24 2012, 04:24 PM
I am getting ready to button up my fuel system after pulling the tank for cleaning and replacing the soft lines.
I have a 72 that a PO carb converted. The return line is capped off back in the engine bay past the plastic fuel line, which seems a bit foolish to plug the line so far back.
Does anyone have a solution for capping the line at the tank? I do evenaually want to change back to FI so I don't want a solution that is permanant.
post Sep 24 2012, 06:29 PM
Resident German
Why not use it? Even with carbs you'd benefit from circulating the fuel ...
Woody
post Sep 25 2012, 03:55 PM
Sandbox Rabblerouser and head toilet scrubber
QUOTE(SirAndy @ Sep 24 2012, 07:29 PM) *
I disagree, recirculating the fuel heats it up. Cool fuel atomizes better. I also believe most manufacturers have gone with returnless systems for that same reason.
post Sep 25 2012, 04:26 PM
Resident German
QUOTE(Woody @ Sep 25 2012, 02:55 PM) *
If you ever had fuel boil in the carb bowls from heat-soak, you'd know that the tank is a much better heat sink than them tiny bowls.
- Lo-Fi Version Time is now: 1st August 2025 - 02:37 AM
