porkchopexpress |
Newbie ![]() Group: Members Posts: 39 Joined: 18-August 12 From: Tucson, AZ Member No.: 14,821 Region Association: Southwest Region ![]() |
I am getting ready to button up my fuel system after pulling the tank for cleaning and replacing the soft lines.
I have a 72 that a PO carb converted. The return line is capped off back in the engine bay past the plastic fuel line, which seems a bit foolish to plug the line so far back. Does anyone have a solution for capping the line at the tank? I do evenaually want to change back to FI so I don't want a solution that is permanant. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,284 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Why not use it? Even with carbs you'd benefit from circulating the fuel ...
(IMG:style_emoticons/default/popcorn[1].gif) |
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Why not use it? Even with carbs you'd benefit from circulating the fuel ... (IMG:style_emoticons/default/popcorn[1].gif) I disagree, recirculating the fuel heats it up. Cool fuel atomizes better. I also believe most manufacturers have gone with returnless systems for that same reason. |
SirAndy |
Why not use it? Even with carbs you'd benefit from circulating the fuel ... (IMG:style_emoticons/default/popcorn[1].gif) I disagree, recirculating the fuel heats it up. Cool fuel atomizes better. I also believe most manufacturers have gone with returnless systems for that same reason. If you ever had fuel boil in the carb bowls from heat-soak, you'd know that the tank is a much better heat sink than them tiny bowls. (IMG:style_emoticons/default/popcorn[1].gif) |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
If you ever had fuel boil in the carb bowls from heat-soak, you'd know that the tank is a much better heat sink than them tiny bowls. (IMG:style_emoticons/default/popcorn[1].gif) Once fuel gets into the bowls the only place it's going is through the jets. There's no use for a return with carbs. |
SirAndy |
If you ever had fuel boil in the carb bowls from heat-soak, you'd know that the tank is a much better heat sink than them tiny bowls. (IMG:style_emoticons/default/popcorn[1].gif) Once fuel gets into the bowls the only place it's going is through the jets. There's no use for a return with carbs. Last i checked there is usually a fuel line connected to that carb ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 02:39 AM |
