> Rear Quarter Panel Repair Ideas
TargaToy
post Feb 5 2012, 08:16 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
So once again I find myself going where the sun don't shine.
Eventually, I plan to post the receipt from where the body shop charged the interim owner for "replacing quarter panel"...but that's fun for another day.
Here's my question: Am I correct that, from the factory, the little void in the point at the rear of the quarter panel (above the tail light) is left empty--or full of spray foam--and that there's a very large glob of seam sealer supposedly preventing tire-slung moisture from finding the foam?
I had to open mine up all the way and I'm toying with actually welding in a custom baffle in front of that pointed tip so that I could seal it up tight from the front side of the baffle. I would do this as part of the process when I fit in the new fender section.
What I want to do is make sure moisture can't get into that rear point and fester.
Anybody who's reworked the rearmost part of the fender/light socket, what have you done???
charliew
post Sep 29 2012, 09:15 AM
I like ospho and use it on almost everything BUT. If you leave a puddle and let it dry or a run when you paint over it, it will make a place that is hollow, it bubbles up, and will easily come loose later on. These places are sometimes hard to see till after the coating on top dries. On a 42 ford jeep I had put so much on while I was doing the whole tub, we decided to reblast it to get it nice and clean for the epoxy coat. I know on the inside of longs and places you can't get to this is tough though. I would suggest useing a air hose with a long blower to try and remove the puddles in the cavity, this might also get it in the gaps in the layers of metal between the spot welds. All you can do is try to do the best method you have available.
I haven't tried it but I bet there web sites on repairing unibody cars and re rustproofing the cavities. I know for a fact only high end shops bother with this.
TargaToy   Rear Quarter Panel Repair Ideas   Feb 5 2012, 08:16 PM
SirAndy   I have had very good results with leaving that are...   Feb 5 2012, 08:37 PM
TargaToy   I have had very good results with leaving that ar...   Feb 5 2012, 09:02 PM
rick 918-S   I'm of two minds here when it comes to that po...   Feb 5 2012, 09:01 PM
TargaToy   I'm of two minds here when it comes to that p...   Feb 5 2012, 09:19 PM
kertwerks   By the way, for this and for other areas like insi...   Feb 6 2012, 07:51 PM
TargaToy   By the way, for this and for other areas like ins...   Feb 6 2012, 11:18 PM
Eric_Shea   https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-as...   Feb 6 2012, 11:33 PM
TargaToy   I can't project myself into the future to kno...   Feb 7 2012, 08:47 PM
euro911   Eric, is that a rust converter, or paint? That loo...   Feb 6 2012, 11:52 PM
ThePaintedMan   Eric, is that a rust converter, or paint? That lo...   Feb 7 2012, 12:37 AM
Eric_Shea   Hey Mark, Check this out... http://www.eastwood....   Feb 7 2012, 12:34 AM
euro911   I just checked out the Evapo-Rust site and watched...   Feb 7 2012, 01:25 AM
ThePaintedMan   Oops! My mistake Mark. What about the popular ...   Feb 7 2012, 01:45 AM
Eric_Shea   Take a look at the first picture I posted. The ...   Feb 7 2012, 09:14 PM
TargaToy   Take a look at the first picture...Now look at ...   Feb 7 2012, 09:56 PM
Socalandy   I used it in my longs and everywhere I could feed ...   Feb 7 2012, 10:07 PM
euro911   Hey Andy, in your last pic, did you spray the East...   Feb 8 2012, 12:01 AM
burton73   I put the Eastwood stuff into the longs through th...   Feb 8 2012, 06:35 PM
Socalandy   I used the repair opening to clean out and spray i...   Feb 8 2012, 11:54 PM
euro911   The Eastwood product looks like it does the trick....   Feb 9 2012, 01:23 AM
jimkelly   so the concensus is to - spray ospho into the long...   Sep 29 2012, 08:51 AM
charliew   I like ospho and use it on almost everything BUT. ...   Sep 29 2012, 09:15 AM
TargaToy   Today, I cleaned up a nose section which will even...   Sep 29 2012, 04:37 PM
- Lo-Fi Version Time is now: 19th July 2025 - 10:12 AM
