Standard 1.7 to 2.0 Upgrade, ...................what's that mean? |
7TPorsh |
Sep 26 2012, 10:52 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I am trying to figure out what I have. PO said it was the "standard" 2.0 upgrade. But I don't know what that is. I smiled and said "oh".
So here is what I found in the glove compartment way back. So 2.0 case? what does that mean? Different cam? solid lifters? is that good? Car slowly started running bad and now I can't seem to get it started and idling. I have changed and relocated the fuel pump and installed a pressure gauge at the carbs...3psi constant. So the investigation moves to the ignition. I took off my pertronix and put the points back, set dwell, played with timing (no light)...no difference. I started reading about dizzys and got dizzy...but I think I will need a better one. So I have dual Webers...and that's all I know. What model? Vacuum...don't know. There is a sticker on them. Is that a rebuild sticker from Internic |
sean_v8_914 |
Oct 2 2012, 07:39 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
carbs are dirty, clogged jets.
remove carbs, remove jets, blow it all out with carb cleaner |
Lo-Fi Version | Time is now: 12th June 2024 - 12:43 PM |
