Master Cylinder Grommet installation help |
tornik550 |
Oct 2 2012, 10:51 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
My master cylinder grommets have a slight leak. They are cracked and old. I purchased some new grommets. I removed the old ones already and did not pay attention to how they were installed. Which side of the grommet goes into the master cylinder- the wide side or the narrow side? Also, when I install the lines from the reservoir, do I push them all the way through the grommet so the line is pushing against the washer in the master cylinder or does the line rest in the bore of the grommet?
Attached image(s) |
pilothyer |
Oct 2 2012, 10:58 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
The wide end goes in first, on top of the washers, then the line just pushes in. You will feel it seat. Since this is not a pressure connection that is all I have ever done and the brake fluid is just gravity fed to the master cylinder.
Lo-Fi Version | Time is now: 13th June 2024 - 03:05 AM |
