Removing transmission Drain Plugs, heat? |
Jon H. |
Oct 3 2012, 08:27 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
I have my transmission apart on the bench and I can't get the drain plug out? I'm not sure if I should use heat or not; out of fear of melting the case? What do you guys think? A little heat with the propane or get glowing with the oxy?
Thanks' Jon |
Dr Evil |
Oct 4 2012, 06:39 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I use up to MAP heat on them with no issue. I do not know about Oxy/acetylene, though.
I find that if heat does not work, I just drill a huge hole in the middle of the plug and use an easy out or other large rod with grippers. It comes out easy then. I have spare plugs if you need that are in perfect shape. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:03 PM |
