Stripped intake stud |
AE354803 |
Oct 3 2012, 10:36 PM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
I have a 2.0 type IV from a 914 in my 912, it has the GA heads and Weber 40 IDFs. Today I was warming it up to change the oil and saw flashing from the intake manifold/head seal area when small backfires occured. Naturally I started to tighten the intake manifold bolts. On the #1 cylinder outboard nut, I felt too much play. I wiggled the stud and pulled it right out!
See the picture below. I was able to find more threads in the hole and thread it back in using 2 nuts so it isn't completely stripped. Only about 1/4" of threads came out with the stud. What should I do here? |
euro911 |
Oct 4 2012, 11:44 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I believe intake manifold studs are M8 x 1.25.
Use a depth gauge to measure the bore, then add the thickness of intake manifold, gasket, washer and nut to come up with the length you'll need. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:13 PM |
