Standard 1.7 to 2.0 Upgrade, ...................what's that mean? |
7TPorsh |
Sep 26 2012, 10:52 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I am trying to figure out what I have. PO said it was the "standard" 2.0 upgrade. But I don't know what that is. I smiled and said "oh".
So here is what I found in the glove compartment way back. So 2.0 case? what does that mean? Different cam? solid lifters? is that good? Car slowly started running bad and now I can't seem to get it started and idling. I have changed and relocated the fuel pump and installed a pressure gauge at the carbs...3psi constant. So the investigation moves to the ignition. I took off my pertronix and put the points back, set dwell, played with timing (no light)...no difference. I started reading about dizzys and got dizzy...but I think I will need a better one. So I have dual Webers...and that's all I know. What model? Vacuum...don't know. There is a sticker on them. Is that a rebuild sticker from Internic |
7TPorsh |
Oct 5 2012, 04:02 PM
looking at the diagram...where are the main jets? I am guessing that's what I need to take out and blow out since the car is idling so it's not the idle jets?
Webers so I am hoping I don;t have to remove the carbs to do this. Anyone know what kind of Webers these are? |
Lo-Fi Version | Time is now: 12th June 2024 - 08:23 PM |
