Grounds |
Grounds |
partwerks |
Oct 11 2012, 09:34 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I thought I had some of the bugs worked out with cleaning some of the electrical connections, but maybe not enough?
One weird thing is when I hit a hard bump in the road, it wants to cut out a bit. After shutting it off, and trying to restart it, the fuel pump did not come on with the key. I let it sit for about a half hour and it took right off. The fuel pressure checked out ok, and there is a pulse going to the injector with a noid light. The water temp when I turned on the parking lights, went up a bit and a bit more when I turned on the lights?? Could it be the ignition switch? I wiggle the key, but does not adversely effect it. Where might I all check for grounds at? This may be a bit different with the Subie engine in it. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:18 AM |
