> Weber Jets, ...what does a good clean one look like?
7TPorsh
post Oct 15 2012, 09:57 AM
7T Porsh
In the process o trying to get the car to run smooth I have removed the jets from my Webers.
If I understand this properly there are three pieces: tube holder, jet, and cap.
As I removed them, one jet had come out of its tube holder and was sitting in the carb. A little coaxing and pressing and I was able to remove the jet fine. I thought I would squeeze the tabs on the holder a little so it would hold the jet better; but in doing so a tab broke off. metal seems very brittle.
Tube can hold jet ok but I think I need a new tube...are these available?
If the jet was not pressed tight into the tube; would it affect performance?
euro911
post Oct 15 2012, 12:11 PM
Gary, I wouldn't be 'changing' any jets until you get it running stable and have the air/fuel ratio checked out.
Just go through the jet cleaning process first. Also, don't over-tighten the jet stack when reinstalling in the carb.
I was using the term 'emulsion tube holder' (instead of 'jet carrier') as the Weber diagram posted on a different thread called it such. Didn't want to add any additional confusion (IMG:style_emoticons/default/confused24.gif)
7TPorsh   Weber Jets   Oct 15 2012, 09:57 AM
7TPorsh   Also what is the best way to clean these? I can s...   Oct 15 2012, 09:59 AM
Elliot Cannon   I used to have trouble with idle jets clogging. I...   Oct 15 2012, 10:13 AM
euro911   Looks like you have a broken upper emulsion tube h...   Oct 15 2012, 10:48 AM
Mark Henry   The correct term is "main jet carrier" d...   Oct 15 2012, 11:48 AM
7TPorsh   So when you guys are tuning carbs...which piece is...   Oct 15 2012, 11:52 AM
euro911   Gary, I wouldn't be 'changing' any jet...   Oct 15 2012, 12:11 PM
Mark Henry   Gary, I wouldn't be 'changing' any je...   Oct 15 2012, 02:11 PM
nolift914   Those are your main jets listed as 135, but if you...   Oct 15 2012, 12:30 PM
Eric_Shea   Agree. Use the "Lean Best" method to tun...   Oct 15 2012, 12:31 PM
bulitt   This brings back memories. Had 45 dcoes on my toy...   Oct 15 2012, 02:12 PM
7TPorsh   Not changing anything ...just curious. Need to cl...   Oct 15 2012, 02:13 PM
euro911   Check and clean the accelerator pump components as...   Oct 15 2012, 03:05 PM
7TPorsh   Thanks Mark, not tuning yet. It was tuned before a...   Oct 15 2012, 03:13 PM
euro911   Found a video on You Tube that should help guide y...   Oct 15 2012, 03:23 PM
rhodyguy   item #23 (small o-ring that seals the idle jet hol...   Oct 16 2012, 07:39 AM
DBCooper   Weber and Dellorto parts are still around, no prob...   Oct 17 2012, 06:01 AM
rhodyguy   interesting tidbit buried on abbot's site. det...   Oct 17 2012, 06:15 AM
7TPorsh   Thanks guys, they are all soaking in carb cleaner ...   Oct 17 2012, 09:48 AM
rhodyguy   blowing the jets backwards doesn't even requir...   Oct 18 2012, 02:14 PM
7TPorsh   Is it easy to get to the bowls while I have the to...   Oct 18 2012, 04:02 PM
euro911   Yes. Did you watch the video (see post #15) :confu...   Oct 18 2012, 04:23 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:22 AM
