| 7TPorsh |
Oct 15 2012, 09:57 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
In the process o trying to get the car to run smooth I have removed the jets from my Webers.
If I understand this properly there are three pieces: tube holder, jet, and cap. As I removed them, one jet had come out of its tube holder and was sitting in the carb. A little coaxing and pressing and I was able to remove the jet fine. I thought I would squeeze the tabs on the holder a little so it would hold the jet better; but in doing so a tab broke off. metal seems very brittle. Tube can hold jet ok but I think I need a new tube...are these available? If the jet was not pressed tight into the tube; would it affect performance? |
| bulitt |
Oct 15 2012, 02:12 PM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
This brings back memories. Had 45 dcoes on my toyota in 1973. Not many places to get parts back then. Guy in the back of autoweek rag-
Al Cosentino was about the only source on the east coast. He ran a business called Forza (faza?). Sent him a check and he mailed the parts, two week turn around! Didn't have the $$$ for a bunch of jets being in college so bought the Weber drill kit and would solder the jets then drill them out. Once determined the right size would order the jets. Luckily the solder never broke loose... (IMG:style_emoticons/default/biggrin.gif) So had 10:1 Arias pistons and a cam and would do the plug cuts to set the A/F ratio Had a detonation and bent a rod once (lean wasn't best here!)... (IMG:style_emoticons/default/chair.gif) Oh to have a wide band back then... (IMG:style_emoticons/default/idea.gif) |
7TPorsh Weber Jets Oct 15 2012, 09:57 AM
7TPorsh Also what is the best way to clean these?
I can s... Oct 15 2012, 09:59 AM
Elliot Cannon I used to have trouble with idle jets clogging. I... Oct 15 2012, 10:13 AM
euro911 Looks like you have a broken upper emulsion tube h... Oct 15 2012, 10:48 AM
Mark Henry The correct term is "main jet carrier" d... Oct 15 2012, 11:48 AM
7TPorsh So when you guys are tuning carbs...which piece is... Oct 15 2012, 11:52 AM
euro911 Gary, I wouldn't be 'changing' any jet... Oct 15 2012, 12:11 PM
Mark Henry
Gary, I wouldn't be 'changing' any je... Oct 15 2012, 02:11 PM
nolift914 Those are your main jets listed as 135, but if you... Oct 15 2012, 12:30 PM
Eric_Shea Agree. Use the "Lean Best" method to tun... Oct 15 2012, 12:31 PM
7TPorsh Not changing anything ...just curious.
Need to cl... Oct 15 2012, 02:13 PM
euro911 Check and clean the accelerator pump components as... Oct 15 2012, 03:05 PM
7TPorsh Thanks Mark, not tuning yet. It was tuned before a... Oct 15 2012, 03:13 PM
euro911 Found a video on You Tube that should help guide y... Oct 15 2012, 03:23 PM
rhodyguy item #23 (small o-ring that seals the idle jet hol... Oct 16 2012, 07:39 AM
DBCooper Weber and Dellorto parts are still around, no prob... Oct 17 2012, 06:01 AM
rhodyguy interesting tidbit buried on abbot's site. det... Oct 17 2012, 06:15 AM
7TPorsh Thanks guys, they are all soaking in carb cleaner ... Oct 17 2012, 09:48 AM
rhodyguy blowing the jets backwards doesn't even requir... Oct 18 2012, 02:14 PM
7TPorsh Is it easy to get to the bowls while I have the to... Oct 18 2012, 04:02 PM
euro911 Yes. Did you watch the video (see post #15) :confu... Oct 18 2012, 04:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:24 PM |
