| 7TPorsh |
Oct 15 2012, 09:57 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
In the process o trying to get the car to run smooth I have removed the jets from my Webers.
If I understand this properly there are three pieces: tube holder, jet, and cap. As I removed them, one jet had come out of its tube holder and was sitting in the carb. A little coaxing and pressing and I was able to remove the jet fine. I thought I would squeeze the tabs on the holder a little so it would hold the jet better; but in doing so a tab broke off. metal seems very brittle. Tube can hold jet ok but I think I need a new tube...are these available? If the jet was not pressed tight into the tube; would it affect performance? |
| euro911 |
Oct 15 2012, 03:05 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Check and clean the accelerator pump components as well (items 10~13 0n the diagram, 2 per carb).
Another item, assure the floats (51) are adjusted properly. You'll need to remove the carb tops to access them. As a last resort, you may need to remove the carbs, partially disassemble them (remove the floats and all jets) and boil-out the carb body to clean out any clogged ports. As to which jet sizes folks run, again, don't do anything until you have a baseline reading with the configuration you currently have. You may already be jetted for the optimum A/F ratio. Each engine is different and there isn't a single magic bullet configuration to follow. Buy a Weber carburetor book (IMG:style_emoticons/default/idea.gif) |
7TPorsh Weber Jets Oct 15 2012, 09:57 AM
7TPorsh Also what is the best way to clean these?
I can s... Oct 15 2012, 09:59 AM
Elliot Cannon I used to have trouble with idle jets clogging. I... Oct 15 2012, 10:13 AM
euro911 Looks like you have a broken upper emulsion tube h... Oct 15 2012, 10:48 AM
Mark Henry The correct term is "main jet carrier" d... Oct 15 2012, 11:48 AM
7TPorsh So when you guys are tuning carbs...which piece is... Oct 15 2012, 11:52 AM
euro911 Gary, I wouldn't be 'changing' any jet... Oct 15 2012, 12:11 PM
Mark Henry
Gary, I wouldn't be 'changing' any je... Oct 15 2012, 02:11 PM
nolift914 Those are your main jets listed as 135, but if you... Oct 15 2012, 12:30 PM
Eric_Shea Agree. Use the "Lean Best" method to tun... Oct 15 2012, 12:31 PM
bulitt This brings back memories. Had 45 dcoes on my toy... Oct 15 2012, 02:12 PM
7TPorsh Not changing anything ...just curious.
Need to cl... Oct 15 2012, 02:13 PM
7TPorsh Thanks Mark, not tuning yet. It was tuned before a... Oct 15 2012, 03:13 PM
euro911 Found a video on You Tube that should help guide y... Oct 15 2012, 03:23 PM
rhodyguy item #23 (small o-ring that seals the idle jet hol... Oct 16 2012, 07:39 AM
DBCooper Weber and Dellorto parts are still around, no prob... Oct 17 2012, 06:01 AM
rhodyguy interesting tidbit buried on abbot's site. det... Oct 17 2012, 06:15 AM
7TPorsh Thanks guys, they are all soaking in carb cleaner ... Oct 17 2012, 09:48 AM
rhodyguy blowing the jets backwards doesn't even requir... Oct 18 2012, 02:14 PM
7TPorsh Is it easy to get to the bowls while I have the to... Oct 18 2012, 04:02 PM
euro911 Yes. Did you watch the video (see post #15) :confu... Oct 18 2012, 04:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:20 AM |
