| aircooledtechguy |
Oct 12 2012, 11:25 PM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
So,. . . My header/muffler system on my shop-car works flawlessly and actually sounds really good too. However, I REALLY love the sound of the Porsche banana can muffs. So I'm thinking of converting my shop-car to a banana can muffler. Switching could also eliminate the occasional dragging of the muffler coming out of steep parking lots. The big issue though is where would I end up mounting the O2 bung so it will read correctly?? I'm thinking that with a muffler like this one below, over on the right side (closest end) near the end would be a good spot. . . What say you??
| Black22 |
Oct 17 2012, 08:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
If its dual inlet, (2 cylinders per inlet) then weld 2 bungs and move the O2 sensor when tuning. Plug the unused one.
Nothing like getting good readings on one half of the engine while the other side is lean and melts! (IMG:style_emoticons/default/blink.gif) |
aircooledtechguy O2 sensor placement on a Banana can Oct 12 2012, 11:25 PM
kg6dxn On the outlet, as hidden as possible, but must be ... Oct 12 2012, 11:35 PM
Black22 From the research I did before mounting mine, all ... Oct 13 2012, 08:13 AM
markyb I have submitted a request to PLX regarding the se... Oct 13 2012, 06:54 PM
kg6dxn Theoretically speaking, The O2 optimum location is... Oct 13 2012, 07:48 PM
aircooledtechguy I've already got a wide-band sensor (LC-1) tha... Oct 13 2012, 08:04 PM
markyb
I've already got a wide-band sensor (LC-1) th... Oct 18 2012, 10:05 AM
markyb here's the reply from PLX, I'm going with ... Oct 17 2012, 06:36 PM
Black22
here's the reply from PLX, I'm going with... Oct 17 2012, 08:04 PM
kg6dxn
If its dual inlet, (2 cylinders per inlet) then w... Oct 17 2012, 09:31 PM
Black22
If its dual inlet, (2 cylinders per inlet) then ... Oct 17 2012, 11:14 PM
edwin I have the Haltech wideband controller and when I ... Oct 18 2012, 01:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 31st May 2026 - 10:28 AM |
