> Clutch Cable Bolt Size?
RustyWa
post Jun 13 2004, 12:43 PM
Working Member
So what is the size of the nut, on the tranny end, holding the wedge on?
I had two nuts "locked" together that came undone the other day, so I went looking for a nyloc nut instead, but couldn't find the correct size.
RustyWa
post Jun 13 2004, 01:33 PM
Working Member
I'll check Lowes again.
7mm x 1.0 sounds about right, couldn't find that size at my primary stops. The 8mm was to big, 6mm was to small. So thought it might be std. and not metric. The existing nut fit on a 1/4"-28 bolt, but it was a little loose, and the nut ended up not fitting at all on the cable.
Thanks
- Lo-Fi Version Time is now: 12th July 2025 - 03:34 PM
