| Spoke |
Oct 20 2012, 09:35 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
The next project for my 914 is converting to 5-lug suspension. I have the front struts and rear hub from a 1972 911 to start with.
The rear will have vented rotors. I have some questions about doing this part of the conversion. Two questions: 1) Will I need longer studs in the rear? Before adding the spacer, a lug would catch with 11 rotations on a stud. After adding the spacer, a lug catches with only 8 rotations. 2) When I add the spacer, the rotor is no longer centered perfectly on the hub. How do I center the rotor on the hub? 911 Hub Hub with spacer Hub with spacer and rotor. 911 rotor has been cut by Eric Shea. Thanks E. ![]() With the spacer, the lug only catches with 8 revolutions, down from 11 in its stock state. Is this enough or do I need longer studs? ![]() With the spacer, the rotor lip that centers it on the hub now misses the hub because of the spacer. How do I center the rotor now? Do I use just the 2 little hold-on screws to center? ![]() One of the calipers that will be used. ![]() |
SirAndy The spacer always goes on after the rotor. Unless ... Oct 20 2012, 10:33 PM
Black22
The spacer always goes on after the rotor. Unless... Oct 20 2012, 10:43 PM
Spoke
As far as stud length goes, my guideline is to us... Oct 21 2012, 10:35 AM
Eric_Shea This spacer goes under the rotor. It is to make up... Oct 20 2012, 10:59 PM
bulitt This is a great kit! Thanks for offering it E... Oct 21 2012, 04:40 AM
Eric_Shea 944s use 50mm studs. I was thinking the exact sam... Oct 21 2012, 11:51 AM
Elliot Cannon
944s use 50mm studs. I was thinking the exact sa... Nov 5 2012, 04:11 PM
Matt Romanowski
944s use 50mm studs. I was thinking the exact sa... Feb 24 2014, 09:27 AM
Spoke I did the open lug test and there was about 3/8 in... Nov 5 2012, 11:25 AM
Cap'n Krusty The rule of thumb that applies here is "threa... Nov 5 2012, 12:02 PM
6freak
The rule of thumb that applies here is "thre... Nov 5 2012, 04:03 PM
Eric_Shea This is my favorite Elliot:
http://www.914world.c... Nov 5 2012, 07:35 PM
Spoke I opted to stay with re-drilled 914 hubs instead o... Nov 18 2012, 06:30 PM
Spoke I made a couple of spacers out of 10mil brass shee... Nov 18 2012, 07:26 PM
sixnotfour wheels can have 1-1.5mm radial runout, lateral is ... Nov 18 2012, 07:48 PM
Eric_Shea :agree:
For a permenant solution, install the rot... Nov 18 2012, 08:06 PM
Jeffs9146
:agree:
For a permenant solution, install the ro... Nov 18 2012, 08:41 PM
Spoke
:agree:
For a permenant solution, install the ro... Nov 18 2012, 08:57 PM
Spoke One more question:
Does the spacer assume that a ... Nov 19 2012, 08:31 AM
Eric_Shea Yes. Nov 19 2012, 09:35 AM
Eric_Shea I'll expound now that I'm not on the iPhon... Nov 19 2012, 10:16 AM
Spoke What is a distance washer?
I was thinking about c... Nov 19 2012, 12:19 PM
Spoke In order to keep the rock shield and not offset th... Nov 19 2012, 09:38 PM
jim_hoyland I'm looking at the same issues. Your solution ... Feb 23 2014, 08:28 AM
Eric_Shea Jim,
In your situation, wouldn't the shield m... Feb 23 2014, 08:56 AM
Spoke
Jerry, why did you end up grinding the caliper an... Feb 24 2014, 11:07 AM
jim_hoyland
Jim,
In your situation, wouldn't the shield ... Feb 25 2014, 03:26 PM
Philip W. Jim,
I just did this, they should pull out after... Feb 25 2014, 07:35 PM
jim_hoyland [quote name='Philip W.' date='Feb 25 2... Feb 25 2014, 08:51 PM
jim_hoyland Thanks Eric, I forgot he used a spacer under the r... Feb 23 2014, 09:23 AM
Eric_Shea I wouldn't set the venting clearance until the... Feb 23 2014, 05:33 PM
Jeff Hail Are those SC or Carrera rear rotors? Looks like th... Feb 23 2014, 06:47 PM
Spoke
Are those SC or Carrera rear rotors? Looks like t... Feb 24 2014, 11:15 AM
Eric_Shea SC. If the rotor fits the groove the pads should f... Feb 23 2014, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:16 PM |
