| MrHyde |
Oct 21 2012, 10:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
I was tinkering away in the garage sand blasting the torsion bar adjusters this morning and thought about bringing down the two wiring harnesses I have in the barn. I know the one that came with my parts car looks like crap and has been cut into many times over a few decades, but the 2nd one I bought looks much more intact, just filthy.
I'm wondering what I can use to clean the dirt/grime/grease/random organic matter off of the wiring harness without affecting the wiring itself. I wont be putting power to the harness for a few months so there should be plenty of dry time if required. Any suggestions ??? Thanks (IMG:style_emoticons/default/beerchug.gif) |
| JeffBowlsby |
Oct 21 2012, 12:20 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,390 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Use dampened rags and wipe them down. Simple green will take most of it off, use paint thinner or acetone if necessary - in well ventilated space and gloves. Careful with the acetone, it will remove the color striping and wire numbers, but will not cause other damage.
The casing is plastic, not rubber. |
MrHyde Wire harness cleaning Oct 21 2012, 10:32 AM
kg6dxn I would use a rag with diesel fuel. Any water base... Oct 21 2012, 10:36 AM
Phoenix-MN This is what I did, for cleaning I used simple gre... Oct 21 2012, 10:40 AM
MrHyde Hmmm.. ok .. I dont have anything else that runs o... Oct 21 2012, 03:59 PM
OmaPossu What is "simple green"? Oct 22 2012, 02:07 AM
9146986 Denatured alcohol works good too, and won't ta... Oct 22 2012, 06:23 AM
cary
All purpose c... Oct 22 2012, 06:32 AM
mr914 I've used WD-40 in the past Oct 22 2012, 03:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 12:22 AM |
