> SS Fuel Line Replacement
jks1981
post Oct 23 2012, 07:54 AM
Hello,
I recently bought my first 914, and within a couple of weeks, gas was pouring out the bottom of it. The previous owner had rubber fuel hose running from the gas tank to the fuel pump in the engine compartment (carbed car). This line had cracked where it exited the firewall under the enginer compartment.
So I am going to replace the tunnel line with stainless, keeping in mind this car is now carbed, does it matter if I use 9.5 or 8mm? Also, where the fuel line exits under the engine compartment, is it best to just connect up some hose to run into the compartment, or is there a better way? It seems the lines are pretty exposed there.
Thanks!
James
ChrisFoley
post Oct 23 2012, 10:59 AM
I am Tangerine Racing
QUOTE(jks1981 @ Oct 23 2012, 08:54 AM) *
... does it matter if I use 9.5 or 8mm? ...
I base the decision of which size to use on the pump location. In back gets 9.5mm, up front gets 8mm.
Either will flow more than enough fuel until you get into big displacement engines.
We use our engine compartment lines to go through the engine shelf and decrease the amount of rubber hose used.
- Lo-Fi Version Time is now: 4th July 2025 - 09:18 PM
