> SS Fuel Line Replacement
jks1981
post Oct 23 2012, 07:54 AM
Hello,
I recently bought my first 914, and within a couple of weeks, gas was pouring out the bottom of it. The previous owner had rubber fuel hose running from the gas tank to the fuel pump in the engine compartment (carbed car). This line had cracked where it exited the firewall under the enginer compartment.
So I am going to replace the tunnel line with stainless, keeping in mind this car is now carbed, does it matter if I use 9.5 or 8mm? Also, where the fuel line exits under the engine compartment, is it best to just connect up some hose to run into the compartment, or is there a better way? It seems the lines are pretty exposed there.
Thanks!
James
scotty b
post Oct 23 2012, 05:36 PM
rust free you say ?
I just today replaced a customers lines with a CFR line. ( carbs ) Took all of maybe 2 hours total to drain tank, remove tank, pull old lines, and install new line ( single for carbs ) Highly recommended (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 4th July 2025 - 07:54 PM
