> Cost of a paint job
Harpo
post Oct 23 2012, 04:21 PM
Good afternoon everyone,
How much should I budget for a paint job? My car was origionally blue and one of the previous owners repainted it red. I would like to go back to the factory blue. I was thinking about sanding down to the origional blue paint or should I just let them add another layer.
Thanks
DAvid
toolguy
post Oct 23 2012, 05:35 PM
Plan on doing it right the first time, or you'll regret it later. . .
Your paint and supplies with be in the $1000 to $2000 alone for good quality paint. .
Hell, a gallon of DP40 primer with hardner and reducer will be $300 and that is jobber cost. .
I have a good friend who has a higher end, quality paint shop, and he always budgets $2000 for paint and supplies, except red's, which are a lot more expensive . . . It's amazing how much tape and paper will be used to do a professional job. . . Next is considering you remove all the doors, hoods and engine lid. . remove all the lights and emblems, handles and such. . you don't want to tape anything you don't have to. .
Sanding and prep will take 2 guys 2 full days, shop rate is $85 hr. . so that is $2500, and that is the outside pannels. . if you want the front and rear trunks done add another hour each. . .
Door jams another hour each. . {Adds up fast, doesn't it}
{I spent a full day on each door blocking and primering them to get them flat. } so doors and jambs and trunks can easily add another $2000-3000
Painter will take 1/2 day another $350. . . then color sand and buff another full day 1 guy. . = $700. .
So at this point you're up to $5000 minimum and you still got to put it back together. . .
I know 8000 - 10000 sound like a lot, but when you look at what has to be done, by the hours, to get a 1st class quality job equal to the original factory paint, that is what it takes if the shop does all the work. . . .
scotty b
post Oct 23 2012, 05:38 PM
rust free you say ?
QUOTE(toolguy @ Oct 23 2012, 03:35 PM) *
thank you (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 9th July 2025 - 04:44 PM
