Bullet |
Member ![]() ![]() Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 ![]() |
I can seem to get my 914 to not run Rich. I have checked Injector spray paterns, replaced cap,rotor, points, condensor,plugs, plug wires. and belive that my vacuum routing is correct. I question the integrety of the MPS. if i remove the vacuum hose that runs to it and clamp it off i get no change at all in performance. I was told by a co-worker that i should drill out the riviots and check to see if it is gummed up. I just removed it and am getting ready to take it apart, when out of curiousity I ohm checked the teminals and this is what i got : pin 8 - pin 10 350 ohms, pin 7 - pin 15 90 ohms. is this normal? does anyone know of any way to check the MPS. Or could any one do a quick ohm check on theese terminals to let me know if that is a correct reading? any help would be greatly apreciated.
Bullet |
I also just discoverd that if i remove the Yellow hose (in the picture below) That the car runs alot better. runs ritch though. abd it will hold an RPM, instead of stumbiling. And it acts alot like it has a vaccum leak, Yet i cannot find one at all. I have checked the intake to head, Plenum to intake pipes, injectors, Throtle body housing, pinced off all the hoses, checked for any open ports on the Plenum. Is there another area that im missing? and i curently do not have my decel valve hooked up to anything. It just seems that it is running really lean. i was able to screw in the idle valve all the way and have the car still run. I dont belive that it is the MPS due to the fact that it holds vaccum and passes the Resistance checks.
(IMG:http://www.pelicanparts.com/914/technical_specs/Vacc_Hose_v3.JPG) |
Lo-Fi Version | Time is now: 8th July 2025 - 09:04 PM |
