Trailing arm bearing, removal trick?? |
toon1 |
Oct 25 2012, 11:25 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Does anyone have a trick to remove the bearing from the trailing arm without ruining it?
I ran into a problem while doing my 5 lug conversion. |
wingnut86 |
Oct 25 2012, 12:49 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Search the threads here and on The Pelican site. All the previous respondents are absolutely correct, and then some. No shortcut on the trailing arms, especially after the crud sets in and you have rubber bushings. I keep 2 sets of bearings in my garage fridge - fully aware that I will NEVER attempt to save trailing arm bearings again - shudder at the visuals of the first couple of attempts (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Note that Eric is a serious "Pro" and has accomplished this more times than he probably wants to remember, and has all the correct tools needed. And, he still has an extra set of frozen bearings next to his cold brew (IMG:style_emoticons/default/blink.gif) - I'm assuming that last part. And I just shipped him some of my headaches to boot (IMG:style_emoticons/default/happy11.gif) I have said it before and will say it again - heat & PB Blaster are your friend, as well as a 3/4" impact wrench and impact sockets to fit... (IMG:style_emoticons/default/evilgrin.gif) There are great threads on our site, just search "trailing arms" or similar... Good luck and wear safety goggles. Dave |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:18 AM |
