Trailing arm bearing, removal trick?? |
toon1 |
Oct 25 2012, 11:25 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Does anyone have a trick to remove the bearing from the trailing arm without ruining it?
I ran into a problem while doing my 5 lug conversion. |
Cap'n Krusty |
Oct 25 2012, 01:18 PM
To add to the chorus. The very act of pressing the hub from the bearing destroys the bearing, as the inner race comes out with the hub. If by some chance it doesn't, there's something wrong with the hub, as the "press fit" isn't.
The Cap'n |
6freak |
Oct 25 2012, 02:31 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
the same why ya put them in ...press the outer race and you will be fine ...ya dont press them in with the center race do ya ...no...if its old ya need new one`s anyway so who care`s....JMO have fun B safe
(IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Oct 25 2012, 03:47 PM
the same why ya put them in ...press the outer race and you will be fine ...ya dont press them in with the center race do ya ...no...if its old ya need new one`s anyway so who care`s....JMO have fun B safe (IMG:style_emoticons/default/smile.gif) Actually, you CAN press them into the trailing arm using the inner race, IF you use a press or threaded tool and steady turning pressure. I don't, but you can. You MUST, however, apply pressure ONLY on the inner races to install the hub. The Cap'n |
Lo-Fi Version | Time is now: 10th June 2024 - 08:26 AM |
