| porbmw |
Oct 5 2012, 06:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None
Any suggestions on how to refinish interior flocking of glove box...or, for that matter, best method and material/paint etc to refinish the outside of the box.
Also, how might one properly repair the nice round hole the PO put in the bottom, presumably to run some wires (IMG:style_emoticons/default/dry.gif) Need two early glove boxes, if I can't get this done right...mine have holes in them. Will post in classifieds... |
| rfuerst911sc |
Oct 26 2012, 04:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Flocking is available at most craft stores. When I did mine I used spray adhesive and then just spread/dropped the flocking on the glue. Let it dry and then used a vacumn to suck up what hadn't stuck to the glue. It was an easy cheap repair and has held up for 2+ years now.
| porbmw |
Oct 26 2012, 06:27 AM
Flocking is available at most craft stores. When I did mine I used spray adhesive and then just spread/dropped the flocking on the glue. Let it dry and then used a vacumn to suck up what hadn't stuck to the glue. It was an easy cheap repair and has held up for 2+ years now. I"m going to give that a go. I have a real ratty one I"ll experiment on first....and hopefully will hone the process to something acceptable.... |
porbmw Fl$#cking glove box Oct 5 2012, 06:39 AM
zymurgist What is it made from? I used Plastimend to make a... Oct 5 2012, 08:23 AM
bobheinonen
What is it made from? I used Plastimend to make ... Oct 5 2012, 11:03 AM
Gint Search is your friend...
http://www.914world.com/... Oct 5 2012, 09:49 AM
porbmw
http://www.914world.com... Oct 5 2012, 10:16 PM
gothspeed Does anyone make a fiberglass glove box replacemen... Oct 5 2012, 03:31 PM
Mikey914
Does anyone make a fiberglass glove box replaceme... Oct 24 2012, 09:40 PM
zonedoubt I'm also looking into doing this to the gloveb... Oct 24 2012, 11:10 AM
Griffinroydonald I used acrylic spackling you would use on Dry wall... Oct 24 2012, 09:37 PM
JawjaPorsche There is one listed on Ebay:
http://www.ebay.com/... Oct 25 2012, 07:06 AM
Mikey914 We're only working on the inner cavity. Not th... Oct 25 2012, 07:09 AM
gothspeed
We're only working on the inner cavity. Not t... Oct 25 2012, 08:23 AM
porbmw
We're only working on the inner cavity. Not t... Oct 25 2012, 11:12 AM
JawjaPorsche My Bad! Did not read original post close enoug... Oct 25 2012, 08:04 AM
zonedoubt Start with a crusty glovebox...
Straighten out ... Nov 21 2012, 09:30 PM
ChrisNPDrider OMG they are a pain in the @ss to re-install
any g... Nov 21 2012, 09:41 PM
zonedoubt I can't see any other way to get them in witho... Nov 21 2012, 09:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:43 AM |
