| larryM |
Oct 27 2012, 01:33 PM
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California
.UPDATED _ solution found - see below
anybody seen this before? Solutions ?? I have a new-in-box KEP-1 pressure plate that I purchased thru GPR of San Luis Obispo (German Parts & Restoration) as part of a complete FW-Clutch conversion package to fit a 901 transaxle to a 3.2 engine . ![]() ![]() today I finally tried to install the clutch the PP bolt holes are not matching - the edges are about 1.5-2.0 mm inset from the matching bolt holes of the flywheel - impossible to bolt up unless I hog out the existing holes in the KEP-1 PP further measuring shows that the OD of the KEP-1 PP is maybe 1.5-2mm mm larger than the ID of the Porsche ring gear looks like - it would require a big hammer or some grinding on the OD to make this fit correctly the label on the box only has the KEP logo and "Stage 1 228mm VW/Porsche Presure Plate" printed on it The Kennedy box says 228 - but the PP inside is a 225 - (a shipping room error somewhere...) the 225 PP does not match up to the 228mm 930 FW/ring gear - just as said below problem solved- see post below . |
| Steve |
Oct 27 2012, 03:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,980 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
If you are using the stock 3.2 flywheel, you will also need an adapter ring from KEP. The pressure plate bolts to this ring. Otherwise they also sell a complete flywheel designed for there 228mm pressure plate and disk.
larryM 3.2/901 conversion KEP Clutch & PP issue Oct 27 2012, 01:33 PM
Krieger I think I have that same kit on my 3.0 to 901. I ... Oct 27 2012, 02:56 PM
Jeffs9146 When I installed my kit on the 3.0L it looked like... Oct 27 2012, 03:09 PM
SirAndy If you are using the stock 3.2 flywheel, you will ... Oct 27 2012, 04:56 PM
larryM p.s.
KEP says that they have no adapter or conve... Nov 1 2012, 11:31 PM
Mark Henry My bet is you are you trying to put a kit designed... Oct 27 2012, 06:26 PM
Mark Henry This is the adapter I'm making for my 3.0 conv... Oct 27 2012, 06:49 PM
larryM so far, the big news here is that there was a 225 ... Oct 27 2012, 09:08 PM
Mark Henry
so far, the big news here is that there was a 225... Oct 27 2012, 10:47 PM
larryM WOW - you nailed it
I just found the GPR invoice... Oct 28 2012, 01:09 PM
Mark Henry
WOW - you nailed it
I just found the GPR invoic... Oct 28 2012, 02:32 PM
larryM I DO NOT have a 245mm g50 FW
- I have a new 930... Oct 28 2012, 08:48 PM
Steve That ring bolts to the flywheel through the recess... Oct 27 2012, 09:26 PM
rfuerst911sc I'm using a KEP Stage II on my 914 GT clone wi... Oct 28 2012, 03:36 AM
Krieger You do not need the gear ring on the 3.2 flywheel.... Oct 28 2012, 09:53 AM
larryM I do NOT use a 3.2 oem FW - the entire package is ... Oct 28 2012, 01:06 PM
SirAndy I do NOT use a 3.2 oem FW
Aha. I am using a stock ... Oct 28 2012, 01:12 PM
Mark Henry
You do not need the gear ring on the 3.2 flywheel... Oct 28 2012, 02:29 PM
patssle However, you can get a brand new flywheel that has... Oct 28 2012, 01:22 PM
larryM re: Starter ring gear - teeth location
fwiw -
t... Oct 29 2012, 01:31 PM
sixnotfour I am interested in the G50 setup. i have an 87 car... Oct 29 2012, 06:25 PM
larryM problem solved - see added edits in original post ... Nov 1 2012, 11:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th December 2025 - 08:06 AM |
