> 3.2/901 conversion KEP Clutch & PP issue
larryM
post Oct 27 2012, 01:33 PM
emoze
.UPDATED _ solution found - see below
anybody seen this before? Solutions ??
I have a new-in-box KEP-1 pressure plate that I purchased thru GPR of San Luis Obispo (German Parts & Restoration) as part of a complete FW-Clutch conversion package to fit a 901 transaxle to a 3.2 engine
. Attached Image
today I finally tried to install the clutch
the PP bolt holes are not matching - the edges are about 1.5-2.0 mm inset from the matching bolt holes of the flywheel -
impossible to bolt up unless I hog out the existing holes in the KEP-1 PP
further measuring shows that the OD of the KEP-1 PP is maybe 1.5-2mm mm larger than the ID of the Porsche ring gear
looks like - it would require a big hammer or some grinding on the OD to make this fit correctly
the label on the box only has the KEP logo and "Stage 1 228mm VW/Porsche Presure Plate" printed on it
The Kennedy box says 228 - but the PP inside is a 225 - (a shipping room error somewhere...)
the 225 PP does not match up to the 228mm 930 FW/ring gear - just as said below
problem solved- see post below
Steve
post Oct 27 2012, 03:14 PM
If you are using the stock 3.2 flywheel, you will also need an adapter ring from KEP. The pressure plate bolts to this ring. Otherwise they also sell a complete flywheel designed for there 228mm pressure plate and disk.
post Oct 27 2012, 04:56 PM
Resident German
QUOTE(Steve @ Oct 27 2012, 02:14 PM) *
Here's what i used, KEP Stage 2 for my 3.6L:
(IMG:http://www.914world.com/bbs2/uploads/post-179-1185423229.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1185423324.jpg)
larryM   3.2/901 conversion KEP Clutch & PP issue   Oct 27 2012, 01:33 PM
Krieger   I think I have that same kit on my 3.0 to 901. I ...   Oct 27 2012, 02:56 PM
Jeffs9146   When I installed my kit on the 3.0L it looked like...   Oct 27 2012, 03:09 PM
Steve   If you are using the stock 3.2 flywheel, you will ...   Oct 27 2012, 03:14 PM
SirAndy   If you are using the stock 3.2 flywheel, you will ...   Oct 27 2012, 04:56 PM
larryM   p.s. KEP says that they have no adapter or conve...   Nov 1 2012, 11:31 PM
Mark Henry   My bet is you are you trying to put a kit designed...   Oct 27 2012, 06:26 PM
Mark Henry   This is the adapter I'm making for my 3.0 conv...   Oct 27 2012, 06:49 PM
larryM   so far, the big news here is that there was a 225 ...   Oct 27 2012, 09:08 PM
Mark Henry   so far, the big news here is that there was a 225...   Oct 27 2012, 10:47 PM
larryM   WOW - you nailed it I just found the GPR invoice...   Oct 28 2012, 01:09 PM
Mark Henry   WOW - you nailed it I just found the GPR invoic...   Oct 28 2012, 02:32 PM
larryM   I DO NOT have a 245mm g50 FW - I have a new 930...   Oct 28 2012, 08:48 PM
Steve   That ring bolts to the flywheel through the recess...   Oct 27 2012, 09:26 PM
rfuerst911sc   I'm using a KEP Stage II on my 914 GT clone wi...   Oct 28 2012, 03:36 AM
Krieger   You do not need the gear ring on the 3.2 flywheel....   Oct 28 2012, 09:53 AM
larryM   I do NOT use a 3.2 oem FW - the entire package is ...   Oct 28 2012, 01:06 PM
SirAndy   I do NOT use a 3.2 oem FW Aha. I am using a stock ...   Oct 28 2012, 01:12 PM
Mark Henry   You do not need the gear ring on the 3.2 flywheel...   Oct 28 2012, 02:29 PM
patssle   However, you can get a brand new flywheel that has...   Oct 28 2012, 01:22 PM
larryM   re: Starter ring gear - teeth location fwiw - t...   Oct 29 2012, 01:31 PM
sixnotfour   I am interested in the G50 setup. i have an 87 car...   Oct 29 2012, 06:25 PM
larryM   problem solved - see added edits in original post ...   Nov 1 2012, 11:26 PM
- Lo-Fi Version Time is now: 4th December 2025 - 08:06 AM
