> 3.2/901 conversion KEP Clutch & PP issue
larryM
post Oct 27 2012, 01:33 PM
emoze
.UPDATED _ solution found - see below
anybody seen this before? Solutions ??
I have a new-in-box KEP-1 pressure plate that I purchased thru GPR of San Luis Obispo (German Parts & Restoration) as part of a complete FW-Clutch conversion package to fit a 901 transaxle to a 3.2 engine
. Attached Image
today I finally tried to install the clutch
the PP bolt holes are not matching - the edges are about 1.5-2.0 mm inset from the matching bolt holes of the flywheel -
impossible to bolt up unless I hog out the existing holes in the KEP-1 PP
further measuring shows that the OD of the KEP-1 PP is maybe 1.5-2mm mm larger than the ID of the Porsche ring gear
looks like - it would require a big hammer or some grinding on the OD to make this fit correctly
the label on the box only has the KEP logo and "Stage 1 228mm VW/Porsche Presure Plate" printed on it
The Kennedy box says 228 - but the PP inside is a 225 - (a shipping room error somewhere...)
the 225 PP does not match up to the 228mm 930 FW/ring gear - just as said below
problem solved- see post below
larryM
post Oct 27 2012, 09:08 PM
emoze
so far, the big news here is that there was a 225 kit vs a 228 kit - that is fascinating!!!
WHY ???? (update - KEP says 225 is for VW bus, 228 is for Porsche)
whatever i have is what GPR sold as a complete conversion for 3.2 to 901, KEP box marked 228
- yes I have the correct adaptor ring gear, no it's not a 245mm FW, no pin in the adaptor ring - PP holes do not match up to ring - about 1-2mm off as stated above
Mark Henry
post Oct 27 2012, 10:47 PM
that's what I do!
QUOTE(larryM @ Oct 27 2012, 11:08 PM) *
WHY ????
The 225 kit does use the 228mm pressure plate, the holes do need slight enlarging (elongating), but it's the adaptor ring that holds it centred in place. You shouldn't have to this as it should be done so let the seller look at it before whipping the drill out.
If you were local I'd look at it for you...fix it for a (IMG:style_emoticons/default/beer.gif)
GPR will come good if there's an issue.
larryM
post Oct 28 2012, 01:09 PM
emoze
WOW - you nailed it
I just found the GPR invoice - it says part number "916-116-911-00 clutch set - 901 - 225 kit"
QUOTE(Mark Henry @ Oct 27 2012, 09:47 PM) *
WHY ????
Mark Henry
post Oct 28 2012, 02:32 PM
that's what I do!
QUOTE(larryM @ Oct 28 2012, 03:09 PM) *
WOW - you nailed it
WHY ????
So is your issue because you have a 245mm flywheel?
If it is and you have motronic you will need a early 3.2 flywheel.
larryM   3.2/901 conversion KEP Clutch & PP issue   Oct 27 2012, 01:33 PM
Krieger   I think I have that same kit on my 3.0 to 901. I ...   Oct 27 2012, 02:56 PM
Jeffs9146   When I installed my kit on the 3.0L it looked like...   Oct 27 2012, 03:09 PM
Steve   If you are using the stock 3.2 flywheel, you will ...   Oct 27 2012, 03:14 PM
SirAndy   If you are using the stock 3.2 flywheel, you will ...   Oct 27 2012, 04:56 PM
larryM   p.s. KEP says that they have no adapter or conve...   Nov 1 2012, 11:31 PM
Mark Henry   My bet is you are you trying to put a kit designed...   Oct 27 2012, 06:26 PM
Mark Henry   This is the adapter I'm making for my 3.0 conv...   Oct 27 2012, 06:49 PM
larryM   so far, the big news here is that there was a 225 ...   Oct 27 2012, 09:08 PM
Mark Henry   so far, the big news here is that there was a 225...   Oct 27 2012, 10:47 PM
larryM   WOW - you nailed it I just found the GPR invoice...   Oct 28 2012, 01:09 PM
Mark Henry   WOW - you nailed it I just found the GPR invoic...   Oct 28 2012, 02:32 PM
larryM   I DO NOT have a 245mm g50 FW - I have a new 930...   Oct 28 2012, 08:48 PM
Steve   That ring bolts to the flywheel through the recess...   Oct 27 2012, 09:26 PM
rfuerst911sc   I'm using a KEP Stage II on my 914 GT clone wi...   Oct 28 2012, 03:36 AM
Krieger   You do not need the gear ring on the 3.2 flywheel....   Oct 28 2012, 09:53 AM
larryM   I do NOT use a 3.2 oem FW - the entire package is ...   Oct 28 2012, 01:06 PM
SirAndy   I do NOT use a 3.2 oem FW Aha. I am using a stock ...   Oct 28 2012, 01:12 PM
Mark Henry   You do not need the gear ring on the 3.2 flywheel...   Oct 28 2012, 02:29 PM
patssle   However, you can get a brand new flywheel that has...   Oct 28 2012, 01:22 PM
larryM   re: Starter ring gear - teeth location fwiw - t...   Oct 29 2012, 01:31 PM
sixnotfour   I am interested in the G50 setup. i have an 87 car...   Oct 29 2012, 06:25 PM
larryM   problem solved - see added edits in original post ...   Nov 1 2012, 11:26 PM
- Lo-Fi Version Time is now: 4th December 2025 - 08:04 AM
