| pcar916 |
Oct 31 2012, 01:27 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I have enough mileage on the 40/60 LSD to measure the breakaway torque. Now that the Paul Guard is no longer at GT and having talked to Matt for internal rebuild specs, I have a question for those of you who track that specification.
Excellent customer support by Paul before him, and now Matt, on my diff by the way, but Matt has no way of knowing what Paul dialed into my diff when it was assembled, and I can't find where I wrote it down. He questioned me at length about my driving style and how the car was to be used before building the unit. Now, before anyone brings it up I know there are more things involved than simply overcoming the pre-load created by the Belleville washers, like having more or fewer actual clutch plates, so feel free to include those assumptions in your descriptions if needed... what breakaway torques (accel/decel) do you clutch-types build into your diff's in our mid-engined machines? For those who never heard of this the "breakaway torque" is the amount of torque you have to apply to one rear wheel (off the ground) to make it rotate when the other wheel is locked in place and can't turn. The differential has a different number for acceleration than deceleration unless it's setup to the same angle for both directions. |
| pcar916 |
Nov 1 2012, 04:23 PM
Good articles and thanks. My ramp angles are 40/60 (accel/decel). I confirmed that when it when disassembled for inspection while in the box to replace the R&P.
I know the higher the preload (and breakaway) the more understeer will be created and the lower it is the more oversteer I'll have. The right amount would be the balance between the two where throttle can be used to modulate between under and oversteer. So my question is pointed to that more than the lockup ratio, even though they both contribute to the handling of the car. |
pcar916 LSD breakaway torques Oct 31 2012, 01:27 PM
sixnotfour Here is a great thread about locking %'s and b... Oct 31 2012, 03:53 PM
pcar916 Read that thread and it's interesting. My LSD ... Nov 1 2012, 02:35 PM
sixnotfour True, but you asked about break away Torque, You w... Nov 1 2012, 02:58 PM
Richard Casto Ron,
I am not helping to answer your original que... Nov 2 2012, 12:24 PM
pcar916 Richard, outstanding writeup. You are correct that... Nov 3 2012, 05:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:13 PM |
