| stugray |
Nov 10 2012, 12:26 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have tried a couple of methods for removing the head studs from the case.
Double Nut rarely works. I bought the NAPA stud removal tool, and while it is the perfect tool when you have room, it does not work in such tight areas as our middle head studs. I looked for all kinds of "stud removal tools", but most of them are for broken studs, not for removing studs without 'munging up' the threads. What does everyone else use? A search does not turn up a simple 10mm stud extractor that wont tear up the threads. Stu |
| SLITS |
Nov 10 2012, 06:52 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Those will still chew up the studs / ruin the threads.
Collet Stud Extractor Set I was only $600 off (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) though you can purchase the collet holder and then add for the metric stud thread size you want. I've used one for removal and installation (no I don't own one, I borrow it). |
| Bartlett 914 |
Nov 14 2012, 10:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Those will still chew up the studs / ruin the threads. Collet Stud Extractor Set I was only $600 off (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) though you can purchase the collet holder and then add for the metric stud thread size you want. I've used one for removal and installation (no I don't own one, I borrow it). I have used this tool. It works fantastic! |
stugray What is the proper Head Stud extraction tool? - Now to reinstall them. Nov 10 2012, 12:26 AM
SLITS Collet stud extractor ... about $250 from Sna... Nov 10 2012, 06:28 AM
Jon H. A few cheaper options; still Snap-on though
http... Nov 10 2012, 06:33 AM
Jon H.
Those will still chew up the studs / ruin the thr... Nov 10 2012, 11:13 AM
SLITS
[quote name='SLITS' post='1765890' date='Nov 10 2... Nov 10 2012, 01:02 PM
bulitt Maybe this set from Summit :confused:
Metric Stu... Nov 10 2012, 07:24 AM
bam914 Every time I have done it, which is a lot, I use t... Nov 10 2012, 07:49 AM
mrbubblehead
Every time I have done it, which is a lot, I use ... Nov 10 2012, 08:49 AM
DBCooper Heat and an impact wrench. Nov 10 2012, 10:46 AM
McMark :agree: No special tools needed. Nov 10 2012, 10:52 AM
patssle I had to take out 2 studs for my engine mount on m... Nov 10 2012, 10:55 AM
preach Perhaps not best used in this case but figured I w... Nov 10 2012, 02:33 PM
stugray
I wish you had a picture. I cant visualize what ... Nov 10 2012, 03:06 PM
preach
I wish you had a picture. I cant visualize what... Nov 10 2012, 03:21 PM
stugray Well thanks for the info!
The stud tool works... Nov 11 2012, 02:36 PM
stugray Never heard an answer:
"When reinstalling th... Nov 13 2012, 05:56 PM
brp986s You chase with a chaser, not a tap. If you chase ... Nov 13 2012, 09:41 PM
mrbubblehead
You chase with a chaser, not a tap. If you chase... Nov 13 2012, 10:06 PM
McMark Don't chase. Just reinstall. Nov 13 2012, 10:17 PM
stugray
Last time I checked the threads are cut with a t... Nov 14 2012, 06:38 PM
rtalich
Last time I checked the threads are cut with a ... Nov 14 2012, 09:36 PM
stugray
rtalich - I still just want to understand.
I AM... Nov 14 2012, 10:06 PM
rtalich Sorry but I don't know the scientific answer e... Nov 15 2012, 09:16 AM
McMark :agree: Can't give you a science-y answer, bu... Nov 15 2012, 11:58 AM
mrbubblehead dont do it bro.... clean the holes out real good w... Nov 15 2012, 03:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:42 PM |
