| Spoke |
Oct 20 2012, 09:35 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
The next project for my 914 is converting to 5-lug suspension. I have the front struts and rear hub from a 1972 911 to start with.
The rear will have vented rotors. I have some questions about doing this part of the conversion. Two questions: 1) Will I need longer studs in the rear? Before adding the spacer, a lug would catch with 11 rotations on a stud. After adding the spacer, a lug catches with only 8 rotations. 2) When I add the spacer, the rotor is no longer centered perfectly on the hub. How do I center the rotor on the hub? 911 Hub Hub with spacer Hub with spacer and rotor. 911 rotor has been cut by Eric Shea. Thanks E. ![]() With the spacer, the lug only catches with 8 revolutions, down from 11 in its stock state. Is this enough or do I need longer studs? ![]() With the spacer, the rotor lip that centers it on the hub now misses the hub because of the spacer. How do I center the rotor now? Do I use just the 2 little hold-on screws to center? ![]() One of the calipers that will be used. ![]() |
| Spoke |
Nov 19 2012, 09:38 PM
In order to keep the rock shield and not offset the calipers, I extended the shield bracket to mount on the back of the caliper.
The caliper needed to have a bit of its webbing filed to fit the bracket on the back. Shield and bracket before mounting the caliper. The caliper is nicely centered on the rotor now and the rock shield is securely mounted. (IMG:style_emoticons/default/smile.gif) |
Spoke 5-Lug Vented Rotors on Rear Oct 20 2012, 09:35 PM
SirAndy The spacer always goes on after the rotor. Unless ... Oct 20 2012, 10:33 PM
Black22
The spacer always goes on after the rotor. Unless... Oct 20 2012, 10:43 PM
Spoke
As far as stud length goes, my guideline is to us... Oct 21 2012, 10:35 AM
Eric_Shea This spacer goes under the rotor. It is to make up... Oct 20 2012, 10:59 PM
bulitt This is a great kit! Thanks for offering it E... Oct 21 2012, 04:40 AM
Eric_Shea 944s use 50mm studs. I was thinking the exact sam... Oct 21 2012, 11:51 AM
Elliot Cannon
944s use 50mm studs. I was thinking the exact sa... Nov 5 2012, 04:11 PM
Matt Romanowski
944s use 50mm studs. I was thinking the exact sa... Feb 24 2014, 09:27 AM
Spoke I did the open lug test and there was about 3/8 in... Nov 5 2012, 11:25 AM
Cap'n Krusty The rule of thumb that applies here is "threa... Nov 5 2012, 12:02 PM
6freak
The rule of thumb that applies here is "thre... Nov 5 2012, 04:03 PM
Eric_Shea This is my favorite Elliot:
http://www.914world.c... Nov 5 2012, 07:35 PM
Spoke I opted to stay with re-drilled 914 hubs instead o... Nov 18 2012, 06:30 PM
Spoke I made a couple of spacers out of 10mil brass shee... Nov 18 2012, 07:26 PM
sixnotfour wheels can have 1-1.5mm radial runout, lateral is ... Nov 18 2012, 07:48 PM
Eric_Shea :agree:
For a permenant solution, install the rot... Nov 18 2012, 08:06 PM
Jeffs9146
:agree:
For a permenant solution, install the ro... Nov 18 2012, 08:41 PM
Spoke
:agree:
For a permenant solution, install the ro... Nov 18 2012, 08:57 PM
Spoke One more question:
Does the spacer assume that a ... Nov 19 2012, 08:31 AM
Eric_Shea Yes. Nov 19 2012, 09:35 AM
Eric_Shea I'll expound now that I'm not on the iPhon... Nov 19 2012, 10:16 AM
Spoke What is a distance washer?
I was thinking about c... Nov 19 2012, 12:19 PM
jim_hoyland I'm looking at the same issues. Your solution ... Feb 23 2014, 08:28 AM
Eric_Shea Jim,
In your situation, wouldn't the shield m... Feb 23 2014, 08:56 AM
Spoke
Jerry, why did you end up grinding the caliper an... Feb 24 2014, 11:07 AM
jim_hoyland
Jim,
In your situation, wouldn't the shield ... Feb 25 2014, 03:26 PM
Philip W. Jim,
I just did this, they should pull out after... Feb 25 2014, 07:35 PM
jim_hoyland [quote name='Philip W.' date='Feb 25 2... Feb 25 2014, 08:51 PM
jim_hoyland Thanks Eric, I forgot he used a spacer under the r... Feb 23 2014, 09:23 AM
Eric_Shea I wouldn't set the venting clearance until the... Feb 23 2014, 05:33 PM
Jeff Hail Are those SC or Carrera rear rotors? Looks like th... Feb 23 2014, 06:47 PM
Spoke
Are those SC or Carrera rear rotors? Looks like t... Feb 24 2014, 11:15 AM
Eric_Shea SC. If the rotor fits the groove the pads should f... Feb 23 2014, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:20 PM |
