| JimmyG |
Nov 17 2012, 04:25 PM
Member ![]() ![]() Group: Members Posts: 146 Joined: 10-September 04 From: Birmingham, AL Member No.: 2,730 Region Association: South East States |
I am going to sell my -6 conversion parts so I wanted to see if someone here would like an engine and tranny all set-up for a 914. The engine/tranny in now in an original -6 and I am going to put the number match engine back together and keep the car all original. The 3.0 has less than 5K miles and has never seen any track time or anything of that nature. I have been selling my conversion car parts because I am not going to have the time to finish with all the other things I have going.I have 10K in the engine alone so this will be a deal for somebody. Engine and tranny: Case sent to Ollie’s for case half-sized and align-bore to std. ARP rod nuts crank and rods 3.0 standard P/C. Pistons used are JE’s part #212435. Cylinders sent to Millenium Tech. for re-nikasil coating . Heads rebuilt 78/79 sizing and ARP studs used. Cams web cam 120/104. Rockers were rebushed and new adjustment hardware. New chains, new ramps, updated idle arm. Hydraulic tensioners. Fan is early 11 blade with later internally regulated alternator, machined to fit. Distributor is standard SC sent to Jerry Woods and recurved to be used with carbs. Ignition system is MSD 6A with Clewett ignition wires. Engine has 2 additional coolers, 1 mounted in rear . Fan controlled VW high performance cooler. Mocal mounted in GT lid. All plumbed with air equip fittings and stainless braided hose. Fly wheel is a special made to mount to the 6 screw 3.0l crank used the push type clutch. Transmission is built on an original 914-6 case. It was set up as a side shift, as a Quaife torque biased diff. The gears, syncros, dog-teeth and shift forks were all torn down and inspected, and replaced if needed. It was reassembled on a T6 aluminum intermediate plate and put together. The gear selected for a carbuerated3.0l. First A, second F, third ZD flipped, fourth V, fifth H. The carbs and the exhaust are not being sold and is not included in the price. These go on the original engine. I have more pics can send them to your email address if you are seriously looking. $10,500 Attached thumbnail(s) |
| JimmyG |
Nov 26 2012, 07:00 AM
JimmyG FS: 3.0 SC Engine /Tranny and coolers and lines Nov 17 2012, 04:25 PM
JmuRiz Cool setup, if I didn't already have a convers... Nov 18 2012, 11:36 AM
JimmyG Thanks Nathan! I spent a lot of time and money... Nov 18 2012, 04:38 PM
gms Jimmy I sent you an email and received no reply? Nov 18 2012, 11:16 PM
JimmyG I didnt know you sent me something Glenn. I'm ... Nov 22 2012, 04:08 PM
eimc What compression ratio are the pistons? I looked o... Nov 24 2012, 07:40 PM
JimmyG I will have to look the number for the pistons. up... Nov 25 2012, 08:50 PM
mboss is the car an original 6? and if so r u saying you... Nov 26 2012, 05:43 PM
JimmyG Yea.. the yellow car the engine is in in the pics ... Nov 27 2012, 08:38 AM
6freak How was the motor for temp`s with that cooler ... Nov 27 2012, 08:49 AM
6freak :D Nov 27 2012, 03:00 PM
JimmyG When I first put the engine in the conversion car ... Nov 27 2012, 03:30 PM
6freak
When I first put the engine in the conversion car... Nov 27 2012, 10:58 PM
JimmyG I have a buyer for the tranny. I will just keep th... Dec 1 2012, 07:48 PM
PanelBilly Now your in the range where I can play. Are you su... Dec 2 2012, 12:55 PM
JimmyG Well Billy, I was asked several times if I would s... Dec 2 2012, 05:58 PM
JimmyG Btt
JmuRiz wants the coolers
Thought I had a buye... Dec 14 2012, 08:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th November 2026 - 05:06 AM |
